[petsc-dev] forget about libmpiuni completely
Jed Brown jed at 59A2.org
Wed Feb 17 16:14:39 CST 2010
On Wed, 17 Feb 2010 13:32:56 -0300, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> But if they shove a #include "mpi.h" into their source code, things
> will work, as long as they use a true MPI implementation...
Only as long as PETSc is using their true MPI, it will not work at all
if PETSc was built with mpiuni.  (That's probably what you meant, but it
wasn't clear to me.)
Jed
