[petsc-dev] forget about libmpiuni completely
Lisandro Dalcin dalcinl at gmail.com
Wed Feb 17 16:44:36 CST 2010
On 17 February 2010 19:14, Jed Brown <jed at 59a2.org> wrote:
> On Wed, 17 Feb 2010 13:32:56 -0300, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> But if they shove a #include "mpi.h" into their source code, things
>> will work, as long as they use a true MPI implementation...
> Only as long as PETSc is using their true MPI, it will not work at all
> if PETSc was built with mpiuni.  (That's probably what you meant, but it
> wasn't clear to me.)
Yep. That's what I meant. I want to make things easy for end-users,
but that does not mean that I want to go too far in order save them
from every detail that could make their code non-portable across
different PETSc configurations.. So if you #include "mpi.h" but use
mpiuni, then sorry... after all you do not need to include "mpi.h",
"petsc.h" does that for you...
Lisandro Dalcin
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
