[petsc-dev] forget about libmpiuni completely
Wed Feb 17 10:41:37 CST 2010
On Feb 17, 2010, at 10:32 AM, Lisandro Dalcin wrote:
> On 17 February 2010 13:06, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Feb 17, 2010, at 9:05 AM, Lisandro Dalcin wrote:
>>> On 17 February 2010 11:45, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> 1) Make mpiuni truly a download package mimicing other ones
>>>> exactly.
>>>> 2) Swallow mpiuni more completely into PETSc, no separate
>>>> libmpiuni, put
>>>> the
>>>> includes/mods in a location they are found automatically without
>>>> the
>>>> extra
>>>> -IXXXX
>>>> 3) Have a half-plant/half-animal model.
>>> I definitely vote for (2) ... No separate libmpiuni (put stuff
>>> libpetscsys), put mpi.*.* in  ${PETSC_ARCH}/include/
>>> However, just in case (think of ./configure --with-mpi=0 --prefix=/
>>> usr)
>>> I think we could do the following:
>>> 1) rename/move "include/mpiuni/mpi.h" to "include/mpiuni.h"
>>> 2) autogenerate a header file "$PETSC_ARCH/include/petscmpi.h",
>>> #include'ing "mpi.h" or "mpiuni.h" depending on configuration.
>>> 3) Change "petsc.h" to #incluide "petscmpi.h" instead of "mpi.h"
>>   Yuck. Users often like to shove a #include "mpi.h" into their
>> source code
>> (even though, of course, when you include petsc.h you don't need to
>> worry
>> about that), with your model it pushes people too much into a
>> "PETSc way".
>>   Your model is clean, but too idealistic I think and would annoy
>> people.
> But if they shove a #include "mpi.h" into their source code, things
> will work, as long as they use a true MPI implementation... My point
> is that if users do want to maintain its code mpiuni-compatible, they
> should not #include "mpi.h", and let #include "petsc.h" handle the MPI
> details...
    I don't want to force them to do that.
    Barry
> Anyway, I'm fine with having $PETSC_ARCH/include/mpi*.* ... It's just
> that I have a bit of fear about a prefix PETSc install --with-mpi=0
> overwriting the mpi.h from a true MPI installation... I know, this
> situation is kinda nonsense, but you know...
> Lisandro Dalcin
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
