[petsc-dev] breakage with python2.2
Tue Feb 2 21:33:26 CST 2010
Previous: 6 PEP 278: Universal Up: What's New in Python Next: 8 PEP
282: The
7 PEP 279: enumerate()
A new built-in function, enumerate(), will make certain loops a bit
clearer. enumerate(thing), where thing is either an iterator or a
sequence, returns a iterator that will return (0, thing[0]), (1,
thing[1]), (2, thing[2]), and so forth.
A common idiom to change every element of a list looks like this:
for i in range(len(L)): item = L[i] # ... compute some result based on
item ... L[i] = result
This can be rewritten using enumerate() as:
for i, item in enumerate(L): # ... compute some result based on
On Feb 2, 2010, at 7:19 PM, Satish Balay wrote:
> Thanks - thats fixes it. The next issue is for Jed.
> global name 'enumerate' is not defined  File "config/configure.py",
> line 229, in petsc_configure
>    framework.configure(out = sys.stdout)
>  File "/home/balay/tmp/petsc-dev/config/BuildSystem/config/
> framework.py", line 907, in configure
>    child.configure()
>  File "/home/balay/tmp/petsc-dev/config/PETSc/utilities/
> cacheDetails.py", line 102, in configure
>    self.executeTest(self.configureCacheDetails)
>  File "/home/balay/tmp/petsc-dev/config/BuildSystem/config/base.py",
> line 97, in executeTest
>    ret = apply(test, args,kargs)
> cacheDetails.py", line 76, in configureCacheDetails
>    (fname, source) = self.getconfFunction(a)
> cacheDetails.py", line 65, in getconfFunction
>    for (m,d) in enumerate(methods):
> Also the current code looks buggy. self.methods[self.method=0]  will
> never get used?
> Satish
> On Tue, 2 Feb 2010, Matthew Knepley wrote:
>> On Tue, Feb 2, 2010 at 5:56 PM, Satish Balay <balay at mcs.anl.gov>
>> wrote:
>>> Matt,
>>> [petsc configure is supporsed to be compatible with python 2.2 and
>>> higher].
>>> But I get the following error [apart from missing
>>> 'os.path.pathsep'] with
>>> python2.2
>>> Any idea how to fix this? [
>> Pushed the fix.
>>  Matt
>>> thanks,
>>> Satish
>>> asterix:/home/balay/tmp/petsc-dev>!py
>>> python2.2 config/configure.py --with-mpi=0
>>>            Configuring PETSc to compile on your system
>>> /home/balay/tmp/petsc-dev/config/PETSc/packages/Matlab.py:21:
>>> Warning:
>>> 'yield' will become a reserved keyword in the future
>>>         CONFIGURATION CRASH  (Please send configure.log to
>>> petsc-maint at mcs.anl.gov)
>>> invalid syntax (Matlab.py, line 21)
>>> File "config/configure.py", line 226, in petsc_configure
>>>   framework =
>>> config.framework.Framework(['--configModules=PETSc.Configure','--
>>> optionsModule=PETSc.compilerOptions']+sys.argv[1:],
>>> loadArgDB = 0)
>>> framework.py",
>>> line 104, in __init__
>>>   self.createChildren()
>>> framework.py",
>>> line 330, in createChildren
>>>   self.getChild(moduleName)
>>> framework.py",
>>> line 315, in getChild
>>>   config.setupDependencies(self)
>>> File "/home/balay/tmp/petsc-dev/config/PETSc/Configure.py", line
>>> 45, in
>>> setupDependencies
>>>   utilityObj                    =
>>> self.framework.require('PETSc.'+d+'.'+utilityName, self)
>>> framework.py",
>>> line 335, in require
>>>   config = self.getChild(moduleName, keywordArgs)
>>> framework.py",
>>> line 288, in getChild
>>>   type   = __import__(moduleName, globals(), locals(),
>>> ['Configure']).Configure
>>> asterix:/home/balay/tmp/petsc-dev>cat configure.log
>>>                           Pushing language C
>>>                           Popping language C
>>>                           Pushing language Cxx
>>>                           Popping language Cxx
>>>                           Pushing language FC
>>>                           Popping language FC
