[petsc-dev] breakage with python2.2
Tue Feb 2 19:19:17 CST 2010
Thanks - thats fixes it. The next issue is for Jed.
global name 'enumerate' is not defined  File "config/configure.py", line 229, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/home/balay/tmp/petsc-dev/config/BuildSystem/config/framework.py", line 907, in configure
    child.configure()
  File "/home/balay/tmp/petsc-dev/config/PETSc/utilities/cacheDetails.py", line 102, in configure
    self.executeTest(self.configureCacheDetails)
  File "/home/balay/tmp/petsc-dev/config/BuildSystem/config/base.py", line 97, in executeTest
    ret = apply(test, args,kargs)
  File "/home/balay/tmp/petsc-dev/config/PETSc/utilities/cacheDetails.py", line 76, in configureCacheDetails
    (fname, source) = self.getconfFunction(a)
  File "/home/balay/tmp/petsc-dev/config/PETSc/utilities/cacheDetails.py", line 65, in getconfFunction
    for (m,d) in enumerate(methods):
Also the current code looks buggy. self.methods[self.method=0]  will never get used?
Satish
On Tue, 2 Feb 2010, Matthew Knepley wrote:
> On Tue, Feb 2, 2010 at 5:56 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Matt,
> > [petsc configure is supporsed to be compatible with python 2.2 and higher].
> > But I get the following error [apart from missing 'os.path.pathsep'] with
> > python2.2
> > Any idea how to fix this? [
> Pushed the fix.
>   Matt
> > thanks,
> > Satish
> > asterix:/home/balay/tmp/petsc-dev>!py
> > python2.2 config/configure.py --with-mpi=0
> >             Configuring PETSc to compile on your system
> > /home/balay/tmp/petsc-dev/config/PETSc/packages/Matlab.py:21: Warning:
> > 'yield' will become a reserved keyword in the future
> >          CONFIGURATION CRASH  (Please send configure.log to
> > petsc-maint at mcs.anl.gov)
> > invalid syntax (Matlab.py, line 21)
> >  File "config/configure.py", line 226, in petsc_configure
> >    framework =
> > config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=PETSc.compilerOptions']+sys.argv[1:],
> > loadArgDB = 0)
> > line 104, in __init__
> >    self.createChildren()
> > line 330, in createChildren
> >    self.getChild(moduleName)
> > line 315, in getChild
> >    config.setupDependencies(self)
> >  File "/home/balay/tmp/petsc-dev/config/PETSc/Configure.py", line 45, in
> > setupDependencies
> >    utilityObj                    =
> > self.framework.require('PETSc.'+d+'.'+utilityName, self)
> > line 335, in require
> >    config = self.getChild(moduleName, keywordArgs)
> > line 288, in getChild
> >    type   = __import__(moduleName, globals(), locals(),
> > ['Configure']).Configure
> > asterix:/home/balay/tmp/petsc-dev>cat configure.log
> >                            Pushing language C
> >                            Popping language C
> >                            Pushing language Cxx
> >                            Popping language Cxx
> >                            Pushing language FC
> >                            Popping language FC
