[petsc-dev] breakage with python2.2
Tue Feb 2 22:31:28 CST 2010
ok - made this change.
Satish
On Tue, 2 Feb 2010, Barry Smith wrote:
> Previous: 6 PEP 278: Universal Up: What's New in Python Next: 8 PEP 282: The
> 7 PEP 279: enumerate()
> A new built-in function, enumerate(), will make certain loops a bit clearer.
> enumerate(thing), where thing is either an iterator or a sequence, returns a
> iterator that will return (0, thing[0]), (1, thing[1]), (2, thing[2]), and so
> forth.
> A common idiom to change every element of a list looks like this:
> for i in range(len(L)): item = L[i] # ... compute some result based on item
> ... L[i] = result
> This can be rewritten using enumerate() as:
> for i, item in enumerate(L): # ... compute some result based on item ... L[i]
> = result
> On Feb 2, 2010, at 7:19 PM, Satish Balay wrote:
> > Thanks - thats fixes it. The next issue is for Jed.
> > global name 'enumerate' is not defined  File "config/configure.py", line
> > 229, in petsc_configure
> >   framework.configure(out = sys.stdout)
> > File "/home/balay/tmp/petsc-dev/config/BuildSystem/config/framework.py",
> > line 907, in configure
> >   child.configure()
> > File "/home/balay/tmp/petsc-dev/config/PETSc/utilities/cacheDetails.py",
> > line 102, in configure
> >   self.executeTest(self.configureCacheDetails)
> > File "/home/balay/tmp/petsc-dev/config/BuildSystem/config/base.py", line 97,
> > in executeTest
> >   ret = apply(test, args,kargs)
> > line 76, in configureCacheDetails
> >   (fname, source) = self.getconfFunction(a)
> > line 65, in getconfFunction
> >   for (m,d) in enumerate(methods):
> > Also the current code looks buggy. self.methods[self.method=0]  will never
> > get used?
> > Satish
> > On Tue, 2 Feb 2010, Matthew Knepley wrote:
> > > On Tue, Feb 2, 2010 at 5:56 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > > Matt,
> > > > [petsc configure is supporsed to be compatible with python 2.2 and
> > > > higher].
> > > > But I get the following error [apart from missing 'os.path.pathsep']
> > > > with
> > > > python2.2
> > > > Any idea how to fix this? [
> > > Pushed the fix.
> > > Matt
> > > > thanks,
> > > > Satish
> > > > asterix:/home/balay/tmp/petsc-dev>!py
> > > > python2.2 config/configure.py --with-mpi=0
> > > >           Configuring PETSc to compile on your system
> > > > /home/balay/tmp/petsc-dev/config/PETSc/packages/Matlab.py:21: Warning:
> > > > 'yield' will become a reserved keyword in the future
> > > >        CONFIGURATION CRASH  (Please send configure.log to
> > > > petsc-maint at mcs.anl.gov)
> > > > invalid syntax (Matlab.py, line 21)
> > > > File "config/configure.py", line 226, in petsc_configure
> > > >  framework =
> > > > config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=PETSc.compilerOptions']+sys.argv[1:],
> > > > loadArgDB = 0)
> > > > line 104, in __init__
> > > >  self.createChildren()
> > > > line 330, in createChildren
> > > >  self.getChild(moduleName)
> > > > line 315, in getChild
> > > >  config.setupDependencies(self)
> > > > File "/home/balay/tmp/petsc-dev/config/PETSc/Configure.py", line 45, in
> > > > setupDependencies
> > > >  utilityObj                    =
> > > > self.framework.require('PETSc.'+d+'.'+utilityName, self)
> > > > line 335, in require
> > > >  config = self.getChild(moduleName, keywordArgs)
> > > > line 288, in getChild
> > > >  type   = __import__(moduleName, globals(), locals(),
> > > > ['Configure']).Configure
> > > > asterix:/home/balay/tmp/petsc-dev>cat configure.log
> > > >                          Pushing language C
> > > >                          Popping language C
> > > >                          Pushing language Cxx
> > > >                          Popping language Cxx
> > > >                          Pushing language FC
> > > >                          Popping language FC
