[petsc-dev] boost problems
Fri Apr 16 15:13:44 CDT 2010
   Well obviously something is wrong with that option and needs to be
fixed. What is it?
    Barry
On Apr 16, 2010, at 2:35 PM, Satish Balay wrote:
> On Fri, 16 Apr 2010, Barry Smith wrote:
>> Satish,
>>  All the nightly builds like
>> http://www.geodynamics.org:8009/PETSc%20dev%20x86%20linux%20single%20nosched%20binbot/builds/879/step-shell_2/1
>> failed last night due to boost issues. Could you please take a look
>> at them
>> and see if this is because of some change you made in the boost.py?
> I think walter at geodynamics - who sent in the patch for --with-boost=1
> to autosearch system-install of boost is redoing these tests to use
> system-install boost.
> Previous builds [from last week] uses '--with-boost=1
> --download-boost=1' but todays uses only '--with-boost=1'
> http://www.geodynamics.org:8009/PETSc%20dev%20x86%20linux%20single%20nosched%20binbot/builds/865/step-shell_2/1
> satish
