[petsc-dev] boost problems
Fri Apr 16 14:35:06 CDT 2010
On Fri, 16 Apr 2010, Barry Smith wrote:
>  Satish,
>   All the nightly builds like
> http://www.geodynamics.org:8009/PETSc%20dev%20x86%20linux%20single%20nosched%20binbot/builds/879/step-shell_2/1
> failed last night due to boost issues. Could you please take a look at them
> and see if this is because of some change you made in the boost.py?
I think walter at geodynamics - who sent in the patch for --with-boost=1
to autosearch system-install of boost is redoing these tests to use
system-install boost.
Previous builds [from last week] uses '--with-boost=1
--download-boost=1' but todays uses only '--with-boost=1'
http://www.geodynamics.org:8009/PETSc%20dev%20x86%20linux%20single%20nosched%20binbot/builds/865/step-shell_2/1
satish
