[petsc-dev] boost problems
Fri Apr 16 15:33:21 CDT 2010
My guess is: Walter is changing all the test builds to use system
boost [now that boost.py can do that] - but some testboxes don't have
system-boost installed yet.
[Per previous e-mail - he is still working on changes to the buildbot
tests..]
Satish
On Fri, 16 Apr 2010, Barry Smith wrote:
>  Well obviously something is wrong with that option and needs to be fixed.
> What is it?
>   Barry
> > > Satish,
> > > All the nightly builds like
> > > http://www.geodynamics.org:8009/PETSc%20dev%20x86%20linux%20single%20nosched%20binbot/builds/879/step-shell_2/1
> > > failed last night due to boost issues. Could you please take a look at
> > > them
> > > and see if this is because of some change you made in the boost.py?
> > I think walter at geodynamics - who sent in the patch for --with-boost=1
> > to autosearch system-install of boost is redoing these tests to use
> > system-install boost.
> > Previous builds [from last week] uses '--with-boost=1
> > --download-boost=1' but todays uses only '--with-boost=1'
> > http://www.geodynamics.org:8009/PETSc%20dev%20x86%20linux%20single%20nosched%20binbot/builds/865/step-shell_2/1
> > satish
