[Facets-devel] PETSC ERROR
Thu Jun 4 15:37:29 CDT 2009
Barry/Matt,
Should we make optfile in PetscIntialize(optfile) optional?
Current code is:
PetscIntialize("file") -> PetscOptionsInsert(optfile) ->
PetscOptionsInsertFile(optfile,PETSC_TRUE)
i.e it gives error if the "optfile" is not found.
Should the code be changed to use:
PetscOptionsInsertFile(optfile,PETSC_FALSE)?
Alternatives would be to expose the flag - a bit higher [i.e use
PetscOptionsInsert(file,flg)] or expose it further up to
PetscIntialize(optfile,flg). But changing PetscIntialize() might not
be desireable.
I'm inclined to use:
PetscIntialize("file") -> PetscOptionsInsert(optfile,PETSC_FALSE) ->
PetscOptionsInsertFile(optfile,flg)
Satish
On Thu, 4 Jun 2009, John R. Cary wrote:
> In the UEDGE tests we get
> oxygen.cary$ grep PETSC */*.out | grep petscopt
> setup/alloc-cxxpy.out:[0]PETSC ERROR: Unable to open Options File petscopt!
> tokgeo_HffCnog_ss/tokHffCnog-cxxpy.out:[0]PETSC ERROR: Unable to open
> tokgeo_HmsCnog_ss/tokHmsCnog-cxxpy.out:[0]PETSC ERROR: Unable to open
> tokgeo_H/tokHsm-cxxpy.out:[0]PETSC ERROR: Unable to open Options File
> petscopt!
> Is this really an error?  The code seems to run fine, but those error
> messages would be disconcerting to a user.
> John
> Facets-devel mailing list
> Facets-devel at ice.txcorp.com
> https://ice.txcorp.com/mailman/listinfo/facets-devel
