[Facets-devel] PETSC ERROR
Thu Jun 4 15:51:20 CDT 2009
On Thu, Jun 4, 2009 at 3:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Barry/Matt,
> Should we make optfile in PetscIntialize(optfile) optional?
Why would the user give an argument for optfile, but not intend it to be
found?
  Matt
> Current code is:
> PetscIntialize("file") -> PetscOptionsInsert(optfile) ->
> PetscOptionsInsertFile(optfile,PETSC_TRUE)
> i.e it gives error if the "optfile" is not found.
> Should the code be changed to use:
> PetscOptionsInsertFile(optfile,PETSC_FALSE)?
> Alternatives would be to expose the flag - a bit higher [i.e use
> PetscOptionsInsert(file,flg)] or expose it further up to
> PetscIntialize(optfile,flg). But changing PetscIntialize() might not
> be desireable.
> I'm inclined to use:
> PetscIntialize("file") -> PetscOptionsInsert(optfile,PETSC_FALSE) ->
> PetscOptionsInsertFile(optfile,flg)
> Satish
> On Thu, 4 Jun 2009, John R. Cary wrote:
> > In the UEDGE tests we get
> > oxygen.cary$ grep PETSC */*.out | grep petscopt
> > setup/alloc-cxxpy.out:[0]PETSC ERROR: Unable to open Options File
> petscopt!
> > tokgeo_HffCnog_ss/tokHffCnog-cxxpy.out:[0]PETSC ERROR: Unable to open
> > Options File petscopt!
> > tokgeo_HmsCnog_ss/tokHmsCnog-cxxpy.out:[0]PETSC ERROR: Unable to open
> > tokgeo_H/tokHsm-cxxpy.out:[0]PETSC ERROR: Unable to open Options File
> > petscopt!
> > Is this really an error?  The code seems to run fine, but those error
> > messages would be disconcerting to a user.
> > John
> > _______________________________________________
> > Facets-devel mailing list
> > Facets-devel at ice.txcorp.com
> > https://ice.txcorp.com/mailman/listinfo/facets-devel
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20090604/98bb9d46/attachment.html>
