MAT_KEEP_ZEROED_ROWS && MatZeroRows() on empty rows.
Tue Jun 2 16:55:32 CDT 2009
On Jun 2, 2009, at 4:45 PM, Lisandro Dalcin wrote:
> On Tue, Jun 2, 2009 at 6:15 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>>  MAT_KEEP_ZEROED_ROWS is a bad name for the option. It should be
>> MAT_KEEP_NONZERO_STRUCTURE
>> The error is correct because putting the diagonal value in will
>> change the
>> nonzero structure in this case.
>>   I will change MAT_KEEP_ZEROED_ROWS to MAT_KEEP_NONZERO_STRUCTURE in
>> petsc-dev unless
>> someone points out that I am wrong.
> I'm fine with this, though I would suggest MAT_KEEP_NONZERO_PATTERN,
   Yup, thanks
    Barry
> just for consistency with other names.
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
