MAT_KEEP_ZEROED_ROWS && MatZeroRows() on empty rows.
Lisandro Dalcin dalcinl at gmail.com
Tue Jun 2 16:45:48 CDT 2009
On Tue, Jun 2, 2009 at 6:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  MAT_KEEP_ZEROED_ROWS is a bad name for the option. It should be
> MAT_KEEP_NONZERO_STRUCTURE
> The error is correct because putting the diagonal value in will change the
> nonzero structure in this case.
>   I will change MAT_KEEP_ZEROED_ROWS to MAT_KEEP_NONZERO_STRUCTURE in
> petsc-dev unless
> someone points out that I am wrong.
I'm fine with this, though I would suggest MAT_KEEP_NONZERO_PATTERN,
just for consistency with other names.
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
