release-3.0.0 broken for C++ builds
Lisandro Dalcin dalcinl at gmail.com
Mon Jul 20 15:35:54 CDT 2009
On Mon, Jul 20, 2009 at 5:01 PM, Barry Smith<bsmith at mcs.anl.gov> wrote:
>  Sorry, fixed.
>  Say, isn't it about time we abolish PetscTruth? Are the C and C++ bool
> compatible with each other and compatible with Fortran 90's logical?
C99 "_Bool" and C++ "bool" are likely compatible, at least if the same
compiler suite is used... in GCC, both have sizeof() == 1 . I remember
this surprised you some time ago, and even you said it was a nonsense
(you gave alignment arguments, though I failed to find any issues
there)...
Regarding Fortran, I'm not so sure about compatibility... we could
have two problems:
1) non-matching sizeof() with the C99/C++ type, though in F90 we could
use logical(kind=XXX), right?
2) Can we be 100% sure that in Fortran .TRUE./.FALSE. match C99/C++
true/false in a bit-by-bit basis? I mean, is .FALSE. a 0 (zero) at the
binary level?
>   Barry
> On Jul 20, 2009, at 12:51 PM, Lisandro Dalcin wrote:
>> Barry, this time you are the guy to blame ;-) (at least for the push)
>> All these lines like below in src/mat/impls/aij/mpi/mpiaij.c are
>> wrong, you do not have implicit bool -> enum in C++.
>> MatStashValuesXXX_Private(...., ignorezeroentries && (addv == ADD_VALUES))
>> libfast in: /usr/local/petsc/3.0.0/src/mat/impls/aij/mpi
>> mpiaij.c: In function PetscErrorCode MatSetValues_MPIAIJ(_p_Mat*,
>> PetscInt, const PetscInt*, PetscInt, const PetscInt*, const
>> PetscScalar*, InsertMode):
>> mpiaij.c:396: error: cannot convert bool to PetscTruth for argument 6
>> to PetscErrorCode MatStashValuesRow_Private(MatStash*, PetscInt,
>> PetscInt, const PetscInt*, const PetscScalar*, PetscTruth)
>> mpiaij.c:398: error: cannot convert bool to PetscTruth for argument 7
>> to PetscErrorCode MatStashValuesCol_Private(MatStash*, PetscInt,
>> PetscInt, const PetscInt*, const PetscScalar*, PetscInt, PetscTruth)
>> mpiaij.c: In function void matsetvaluesmpiaij_(_p_Mat**, PetscInt*,
>> const PetscInt*, PetscInt*, const PetscInt*, const PetscScalar*,
>> InsertMode*, PetscErrorCode*):
>> mpiaij.c:5242: error: cannot convert bool to PetscTruth for argument 6
>> mpiaij.c:5244: error: cannot convert bool to PetscTruth for argument 7
>> Lisandro Dalcín
>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>> Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
