release-3.0.0 broken for C++ builds
Mon Jul 20 15:49:29 CDT 2009
On Jul 20, 2009, at 3:35 PM, Lisandro Dalcin wrote:
> On Mon, Jul 20, 2009 at 5:01 PM, Barry Smith<bsmith at mcs.anl.gov>
> wrote:
>>  Sorry, fixed.
>>  Say, isn't it about time we abolish PetscTruth? Are the C and C++
>> bool
>> compatible with each other and compatible with Fortran 90's logical?
> C99 "_Bool" and C++ "bool" are likely compatible, at least if the same
> compiler suite is used... in GCC, both have sizeof() == 1 . I remember
> this surprised you some time ago, and even you said it was a nonsense
> (you gave alignment arguments, though I failed to find any issues
> there)...
    So in C99 and C++ the boolean type has a different name? That
seems really stupid.
So we will still need a PetscTruth macro that maps to bool in c++ and
_Bool in c?
Then it is not worth changing.
    Barry
> Regarding Fortran, I'm not so sure about compatibility... we could
> have two problems:
> 1) non-matching sizeof() with the C99/C++ type, though in F90 we could
> use logical(kind=XXX), right?
> 2) Can we be 100% sure that in Fortran .TRUE./.FALSE. match C99/C++
> true/false in a bit-by-bit basis? I mean, is .FALSE. a 0 (zero) at the
> binary level?
>>   Barry
>> On Jul 20, 2009, at 12:51 PM, Lisandro Dalcin wrote:
>>> Barry, this time you are the guy to blame ;-) (at least for the
>>> push)
>>> All these lines like below in src/mat/impls/aij/mpi/mpiaij.c are
>>> wrong, you do not have implicit bool -> enum in C++.
>>> MatStashValuesXXX_Private(...., ignorezeroentries && (addv ==
>>> ADD_VALUES))
>>> libfast in: /usr/local/petsc/3.0.0/src/mat/impls/aij/mpi
>>> mpiaij.c: In function PetscErrorCode MatSetValues_MPIAIJ(_p_Mat*,
>>> PetscInt, const PetscInt*, PetscInt, const PetscInt*, const
>>> PetscScalar*, InsertMode):
>>> mpiaij.c:396: error: cannot convert bool to PetscTruth for
>>> argument 6
>>> to PetscErrorCode MatStashValuesRow_Private(MatStash*, PetscInt,
>>> PetscInt, const PetscInt*, const PetscScalar*, PetscTruth)
>>> mpiaij.c:398: error: cannot convert bool to PetscTruth for
>>> argument 7
>>> to PetscErrorCode MatStashValuesCol_Private(MatStash*, PetscInt,
>>> PetscInt, const PetscInt*, const PetscScalar*, PetscInt, PetscTruth)
>>> mpiaij.c: In function void matsetvaluesmpiaij_(_p_Mat**, PetscInt*,
>>> const PetscInt*, PetscInt*, const PetscInt*, const PetscScalar*,
>>> InsertMode*, PetscErrorCode*):
>>> mpiaij.c:5242: error: cannot convert bool to PetscTruth for
>>> argument 6
>>> mpiaij.c:5244: error: cannot convert bool to PetscTruth for
>>> argument 7
>>> Lisandro Dalcín
>>> Centro Internacional de Métodos Computacionales en Ingeniería
>>> (CIMEC)
>>> Instituto de Desarrollo Tecnológico para la Industria Química
>>> (INTEC)
>>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>>> Tel/Fax: +54-(0)342-451.1594
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
