about viewer formats
Lisandro Dalcin dalcinl at gmail.com
Mon Nov 3 13:56:05 CST 2008
I'll take a look. This week I'm going to be really busy, so I cannot
promise anything ...
On Mon, Nov 3, 2008 at 4:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 3, 2008, at 1:36 PM, Lisandro Dalcin wrote:
>> On Mon, Nov 3, 2008 at 2:34 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>  Done and pushed.
>> OK. Many thanks,
>>> I guess at one time we had it in our heads that NO format names would be
>>> shared among different
>>> viewers, but now I don't see why some basic ones cannot be shared.
>> BTW, Does it make sense to require the type_name being already set (I
>> mean, using the PetscValidType macro) before setting the format?
>  Hmm, it will likely get overwritten by the PetscViewerCreate_XXX() and
> hence be ignored and thus confusing to users. Thus for user friendlyness
> maybe we should not allow early setting.
>   Looking at a few of the PetscViewerCreate_XXX() I see that we are
> inconsistent
> in setting the viewer->format or not. This is bad, we should either always
> set
> it, or never set it (and only have it set in the PetscViewerCreate()).????
> Will you change the code to always set it in each PetscViewerCreate_XXX()
> please?
>  Barry
>>> On Nov 3, 2008, at 7:50 AM, Lisandro Dalcin wrote:
>>>> Barry, I saw you commit removing PETSC_VIEWER_BINARY_NATIVE. This
>>>> makes me think that PETSC_VIEWER_ASCII_DEFAULT and
>>>> PETSC_VIEWER_BINARY_DEFAULT (which is NOT used in sources) are a bit
>>>> redundat, Why not to remove both and add a new PETSC_VIEWER_DEFAULT?
>>>> Does it make sense?
>> Lisandro Dalcín
>> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
>> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
>> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
>> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
>> Tel/Fax: +54-(0)342-451.1594
Lisandro Dalcín
