[PETSC #17275] Rank of the neighboring processors
Richard Katz rfk22 at cam.ac.uk
Thu Feb 7 17:29:56 CST 2008
DAGetNeighbors() will also be useful in src/contrib/semiLagrangian/
I will work in in there eventually.
Rich
On Feb 7, 2008, at 10:55 PM, Barry Smith wrote:
>   Mehdi,
>     This functionality is now in PETSc-dev called DAGetNeighbors(),
> I think you should be able
> to use that and remove your code to compute the neighbors.
>    Barry
> On Feb 7, 2008, at 4:36 PM, Mehdi Bostandoost wrote:
>> Hi
>> I am working on Navier stokes equation and lagrangian particles
>> using Petsc.I am done with the main code.I had the same problem
>> that you described, so for this code,I already wrote couple of
>> subroutine that take care of this issue for DA objects. but it
>> will be really a good addition to petsc,if they can add that.
>> here is the subroutine(I dont have this subroutine in my code like
>> this.I just copy and paste different part of it from different
>> part of my code to make an example).
>> subroutine findneighbours
>> implicit none
>> integer :: domainsize
>> integer :: rank
>> integer :: xs,xe,xm
>> integer :: gxs,gxe,gxm
>> integer :: ys,ye,ym
>> integer :: gys,gye,gym
>> integer :: zs,ze,zm
>> integer :: gzs,gze,gzm
>> integer :: xsl,ysl,zsl ! local index beginning
>> integer :: xel,yel,zel ! local index ending
>> integer,allocatable:: xsdomains(:)
>> integer,allocatable:: xedomains(:)
>> integer,allocatable:: ysdomains(:)
>> integer,allocatable:: yedomains(:)
>> integer,allocatable:: zsdomains(:)
>> integer,allocatable:: zedomains(:)
>> integer::xleftdomainrank
>> integer::yleftdomainrank
>> integer::zleftdomainrank
>> integer::xrightdomainrank
>> integer::yrightdomainrank
>> integer::zrightdomainrank
>> integer::nprocx
>> integer::nprocy
>> integer::nprocz
>> integer::nx=25
>> integer::ny=35
>> integer::nz=45
>> integer::dof1=3
>> integer::s=4
>> integer :: ierr
>> integer :: i
>> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>> CHKERRQ(ierr)
>> call MPI_Comm_size(PETSC_COMM_WORLD,domainsize,ierr)
>> CHKERRQ(ierr)
>> call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
>> CHKERRQ(ierr)
>> ALLOCATE(xsdomains(domainsize),STAT=status)
>> if(status/=0)then
>> write(logfile,*) 'memory allocation problem xsdomain'
>> call programabort
>> endif
>> xsdomains(:)=-10
>> ALLOCATE(xedomains(domainsize),STAT=status)
>> if(status/=0)then
>> write(logfile,*) 'memory allocation problem xedomain'
>> call programabort
>> endif
>> xedomains(:)=-10
>> ALLOCATE(ysdomains(domainsize),STAT=status)
>> if(status/=0)then
>> write(logfile,*) 'memory allocation problem ysdomain'
>> call programabort
>> endif
>> ysdomains(:)=-10
>> ALLOCATE(yedomains(domainsize),STAT=status)
>> if(status/=0)then
>> write(logfile,*) 'memory allocation problem yedomain'
>> call programabort
>> endif
>> yedomains(:)=-10
>> ALLOCATE(zsdomains(domainsize),STAT=status)
>> if(status/=0)then
>> write(logfile,*) 'memory allocation problem zsdomain'
>> call programabort
>> endif
>> zsdomains(:)=-10
>> ALLOCATE(zedomains(domainsize),STAT=status)
>> if(status/=0)then
>> write(logfile,*) 'memory allocation problem zedomain'
>> call programabort
>> endif
>> zedomains(:)=-10
>> call DACreate3d(PETSC_COMM_WORLD,DA_NONPERIODIC,DA_STENCIL_BOX,
>> & nx,ny,nz,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,
>> & dof1,s,
>> & PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,
>> & PETSC_NULL_INTEGER,daa,ierr)
>> CHKERRQ(ierr)
>> call DAGetCorners(daa,xs,ys,zs,xm,ym,zm,ierr)
>> CHKERRQ(ierr)
>> call DAGetGhostCorners(daa,gxs,gys,gzs,gxm,gym,gzm,ierr)
>> CHKERRQ(ierr)
>> ! finding the neighbors
>> xsdomains(rank+1)=xs
>> call MPI_ALLGATHER(xs,1,MPI_INTEGER,
>> & xsdomains ,1,MPI_INTEGER,
>> & PETSC_COMM_WORLD,ierr)
>> CHKERRQ(ierr)
>> call MPI_ALLGATHER(xe,1,MPI_INTEGER,
>> & xedomains ,1,MPI_INTEGER,
>> CHKERRQ(ierr)
>> call MPI_ALLGATHER(ys,1,MPI_INTEGER,
>> & ysdomains ,1,MPI_INTEGER,
>> CHKERRQ(ierr)
>> call MPI_ALLGATHER(ye,1,MPI_INTEGER,
>> & yedomains ,1,MPI_INTEGER,
>> CHKERRQ(ierr)
>> call MPI_ALLGATHER(zs,1,MPI_INTEGER,
>> & zsdomains ,1,MPI_INTEGER,
>> CHKERRQ(ierr)
>> call MPI_ALLGATHER(ze,1,MPI_INTEGER,
>> & zedomains ,1,MPI_INTEGER,
>> CHKERRQ(ierr)
>> xleftdomainrank=-10
>> yleftdomainrank=-10
>> zleftdomainrank=-10
>> xrightdomainrank=-10
>> yrightdomainrank=-10
>> zrightdomainrank=-10
>> do i=1,domainsize
>> if(xs==1)then
>> xleftdomainrank=-10
>> endif
>> if(ys==1)then
>> yleftdomainrank=-10
>> endif
>> if(zs==1)then
>> zleftdomainrank=-10
>> endif
>> if(xe==nx)then
>> endif
>> if(ye==ny)then
>> endif
>> if(ze==nz)then
>> endif
>> enddo
>> do i=1,domainsize
>> if((xs-1)==xedomains(i) .and.
>> & ys==ysdomains(i) .and. ye==yedomains(i) .and.
>> & zs==zsdomains(i) .and. ze==zedomains(i)
>> & )then
>> xleftdomainrank=i-1
>> endif
>> if((ys-1)==yedomains(i) .and.
>> & xs==xsdomains(i) .and. xe==xedomains(i) .and.
>> & )then
>> yleftdomainrank=i-1
>> endif
>> if((zs-1)==zedomains(i) .and.
>> & )then
>> zleftdomainrank=i-1
>> endif
>> enddo
>> do i=1,domainsize
>> if((xe+1)==xsdomains(i) .and.
>> & )then
>> xrightdomainrank=i-1
>> endif
>> if((ye+1)==ysdomains(i) .and.
>> & )then
>> yrightdomainrank=i-1
>> endif
>> if((ze+1)==zsdomains(i) .and.
>> & )then
>> zrightdomainrank=i-1
>> endif
>> enddo
>> ! end of finding the neighbors
>> DEALLOCATE(xsdomains,STAT=status)
>> if(status/=0)then
>> write(logfile,*) 'memory deallocation problem'
>> call programabort
>> endif
>> DEALLOCATE(xedomains,STAT=status)
>> if(status/=0)then
>> call programabort
>> endif
>> DEALLOCATE(ysdomains,STAT=status)
>> if(status/=0)then
>> call programabort
>> endif
>> DEALLOCATE(yedomains,STAT=status)
>> if(status/=0)then
>> call programabort
>> endif
>> DEALLOCATE(zsdomains,STAT=status)
>> if(status/=0)then
>> call programabort
>> endif
>> DEALLOCATE(zedomains,STAT=status)
>> if(status/=0)then
>> call programabort
>> endif
>> call DADestroy(daa,ierr)
>> call PetscFinalize(ierr)
>> return
>> end
>> I hope it will be helpful.if you have question come back to me.
>> Best Regard
>> Mehdi
>> Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Feb 6, 2008, at 6:38 AM, Tobias Kempe wrote:
>> > Hi Barry,
>> > i have to propose you an additional PETSc feature that could
>> > interesting for
>> > some users. In our lagrangian particle tracking it is neccessary to
>> > send the
>> > particle data to some specific processor - the new particle "master
>> > processor" which performs the evaluation of the equations of motion
>> > for this
>> > particle.
>> > In general we can do this with the MPI_isend, MPI_irecv routines.
>> > In the PETSc environment this may be realized by an MPI_vector
>> Do you mean a PETSc vector of type VECMPI, that is a parallel Vec?
>> > with different
>> > numer of entrys on each processor. The entrys of this MPI_vector
>> may
>> > be
>> > adressed by its index and the rank of the processor where you wish
>> > to set
>> > the value.
>> Do you mean something like
>> VecSetValues(vec,n,ranks,localindices,values)
>> where ranks[n], localindices[n], values[n]? Much like VecSetValues()
>> with the "global indices"
>> replaced with ranks,localindices?
>> Or do you want something more like a VecScatter operation where the
>> "global indices"
>> are replaced with ranks,localindices
>> Barry
>> > Perhaps it is possible to realize this feature in following petsc
>> > releases.
>> > Best regards,
>> > Tobias
>> > Am Samstag 02 Februar 2008 schrieben Sie:
>> >> Tobias,
>> >> I have added DAGetNeighbors(). You will need to use petsc-dev
>> >> see the developers
>> >> page link from www.mcs.anl.gov/petsc
>> >> Please let us know if you have any troubles.
>> >> Barry
>> >> On Feb 1, 2008, at 3:00 AM, Tobias Kempe wrote:
>> >>> Hi PETSc team,
>> >>> we are using distributed arrays for the communication of the
>> >>> processors in our
>> >>> domain decomposition. Nomally the user dont has to worry obout
>> the
>> >>> rank of
>> >>> the neighboring processors. Now we wont to compute large
>> amounts of
>> >>> particles
>> >>> in viscous fluids. The problem is when a particle leaves the
>> >>> physical
>> >>> domain, an other processer becomes the "master" of this particle.
>> >>> With the
>> >>> backround of this lagrangian particle tracking it becomes
>> neccesarry
>> >>> to
>> >>> determine the ranks of the neighboring processors in order to
>> send
>> >>> particle
>> >>> specific data to this processors.
>> >>> Is there some PETSc routine to dertermine the rank of the
>> >>> neighboring
>> >>> processors in the east, west, front ..... and so on?
>> >>> Thank you very much.
>> >>> Best regards
>> >>> Tobias Kempe
>> >>> Dipl.-Ing. Tobias Kempe
>> >>> Technische Universit?? Dresden
>> >>> Institut f?? Str??ungsmechanik
>> >>> Tel.: 0351-46336651
>> >>> Fax: 0351-46335246
>> >>> E-Mail: tobias.kempe at ism.mw.tu-dresden.de
>> > Tel.: 0351-46336651
>> > Fax: 0351-46335246
>> Looking for last minute shopping deals? Find them fast with Yahoo!
>> Search.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20080207/bd52f5b8/attachment.html>
