[PETSC #17275] Rank of the neighboring processors
Thu Feb 7 16:55:38 CST 2008
   Mehdi,
     This functionality is now in PETSc-dev called DAGetNeighbors(), I
think you should be able
to use that and remove your code to compute the neighbors.
    Barry
On Feb 7, 2008, at 4:36 PM, Mehdi Bostandoost wrote:
> Hi
> I am working on Navier stokes equation and lagrangian particles
> using Petsc.I am done with the main code.I had the same problem that
> you described, so for this code,I already wrote couple of subroutine
> that take care of this issue for DA objects. but it will be really a
> good addition to petsc,if they can add that.
> here is the subroutine(I dont have this subroutine in my code like
> this.I just copy and paste different part of it from different part
> of my code to make an example).
> subroutine findneighbours
> implicit none
> integer :: domainsize
> integer :: rank
> integer :: xs,xe,xm
> integer :: gxs,gxe,gxm
> integer :: ys,ye,ym
> integer :: gys,gye,gym
> integer :: zs,ze,zm
> integer :: gzs,gze,gzm
> integer :: xsl,ysl,zsl ! local index beginning
> integer :: xel,yel,zel ! local index ending
> integer,allocatable:: xsdomains(:)
> integer,allocatable:: xedomains(:)
> integer,allocatable:: ysdomains(:)
> integer,allocatable:: yedomains(:)
> integer,allocatable:: zsdomains(:)
> integer,allocatable:: zedomains(:)
> integer::xleftdomainrank
> integer::yleftdomainrank
> integer::zleftdomainrank
> integer::xrightdomainrank
> integer::yrightdomainrank
> integer::zrightdomainrank
> integer::nprocx
> integer::nprocy
> integer::nprocz
> integer::nx=25
> integer::ny=35
> integer::nz=45
> integer::dof1=3
> integer::s=4
> integer :: ierr
> integer :: i
> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
> CHKERRQ(ierr)
> call MPI_Comm_size(PETSC_COMM_WORLD,domainsize,ierr)
> CHKERRQ(ierr)
> call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
> CHKERRQ(ierr)
> ALLOCATE(xsdomains(domainsize),STAT=status)
> if(status/=0)then
> write(logfile,*) 'memory allocation problem xsdomain'
> call programabort
> endif
> xsdomains(:)=-10
> ALLOCATE(xedomains(domainsize),STAT=status)
> if(status/=0)then
> write(logfile,*) 'memory allocation problem xedomain'
> call programabort
> endif
> xedomains(:)=-10
> ALLOCATE(ysdomains(domainsize),STAT=status)
> if(status/=0)then
> write(logfile,*) 'memory allocation problem ysdomain'
> call programabort
> endif
> ysdomains(:)=-10
> ALLOCATE(yedomains(domainsize),STAT=status)
> if(status/=0)then
> write(logfile,*) 'memory allocation problem yedomain'
> call programabort
> endif
> yedomains(:)=-10
> ALLOCATE(zsdomains(domainsize),STAT=status)
> if(status/=0)then
> write(logfile,*) 'memory allocation problem zsdomain'
> call programabort
> endif
> zsdomains(:)=-10
> ALLOCATE(zedomains(domainsize),STAT=status)
> if(status/=0)then
> write(logfile,*) 'memory allocation problem zedomain'
> call programabort
> endif
> zedomains(:)=-10
> call DACreate3d(PETSC_COMM_WORLD,DA_NONPERIODIC,DA_STENCIL_BOX,
> & nx,ny,nz,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,
> & dof1,s,
> & PETSC_NULL_INTEGER,PETSC_NULL_INTEGER,
> & PETSC_NULL_INTEGER,daa,ierr)
> CHKERRQ(ierr)
> call DAGetCorners(daa,xs,ys,zs,xm,ym,zm,ierr)
> CHKERRQ(ierr)
> call DAGetGhostCorners(daa,gxs,gys,gzs,gxm,gym,gzm,ierr)
> CHKERRQ(ierr)
> ! finding the neighbors
> xsdomains(rank+1)=xs
> call MPI_ALLGATHER(xs,1,MPI_INTEGER,
> & xsdomains ,1,MPI_INTEGER,
> & PETSC_COMM_WORLD,ierr)
> CHKERRQ(ierr)
> call MPI_ALLGATHER(xe,1,MPI_INTEGER,
> & xedomains ,1,MPI_INTEGER,
> CHKERRQ(ierr)
> call MPI_ALLGATHER(ys,1,MPI_INTEGER,
> & ysdomains ,1,MPI_INTEGER,
> CHKERRQ(ierr)
> call MPI_ALLGATHER(ye,1,MPI_INTEGER,
> & yedomains ,1,MPI_INTEGER,
> CHKERRQ(ierr)
> call MPI_ALLGATHER(zs,1,MPI_INTEGER,
> & zsdomains ,1,MPI_INTEGER,
> CHKERRQ(ierr)
> call MPI_ALLGATHER(ze,1,MPI_INTEGER,
> & zedomains ,1,MPI_INTEGER,
> CHKERRQ(ierr)
> xleftdomainrank=-10
> yleftdomainrank=-10
> zleftdomainrank=-10
> xrightdomainrank=-10
> yrightdomainrank=-10
> zrightdomainrank=-10
> do i=1,domainsize
> if(xs==1)then
> xleftdomainrank=-10
> endif
> if(ys==1)then
> yleftdomainrank=-10
> endif
> if(zs==1)then
> zleftdomainrank=-10
> endif
> if(xe==nx)then
> endif
> if(ye==ny)then
> endif
> if(ze==nz)then
> endif
> enddo
> do i=1,domainsize
> if((xs-1)==xedomains(i) .and.
> & ys==ysdomains(i) .and. ye==yedomains(i) .and.
> & zs==zsdomains(i) .and. ze==zedomains(i)
> & )then
> xleftdomainrank=i-1
> endif
> if((ys-1)==yedomains(i) .and.
> & xs==xsdomains(i) .and. xe==xedomains(i) .and.
> & )then
> yleftdomainrank=i-1
> endif
> if((zs-1)==zedomains(i) .and.
> & )then
> zleftdomainrank=i-1
> endif
> enddo
> do i=1,domainsize
> if((xe+1)==xsdomains(i) .and.
> & )then
> xrightdomainrank=i-1
> endif
> if((ye+1)==ysdomains(i) .and.
> & )then
> yrightdomainrank=i-1
> endif
> if((ze+1)==zsdomains(i) .and.
> & )then
> zrightdomainrank=i-1
> endif
> enddo
> ! end of finding the neighbors
> DEALLOCATE(xsdomains,STAT=status)
> if(status/=0)then
> write(logfile,*) 'memory deallocation problem'
> call programabort
> endif
> DEALLOCATE(xedomains,STAT=status)
> if(status/=0)then
> call programabort
> endif
> DEALLOCATE(ysdomains,STAT=status)
> if(status/=0)then
> call programabort
> endif
> DEALLOCATE(yedomains,STAT=status)
> if(status/=0)then
> call programabort
> endif
> DEALLOCATE(zsdomains,STAT=status)
> if(status/=0)then
> call programabort
> endif
> DEALLOCATE(zedomains,STAT=status)
> if(status/=0)then
> call programabort
> endif
> call DADestroy(daa,ierr)
> call PetscFinalize(ierr)
> return
> end
> I hope it will be helpful.if you have question come back to me.
> Best Regard
> Mehdi
> Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 6, 2008, at 6:38 AM, Tobias Kempe wrote:
> > Hi Barry,
> > i have to propose you an additional PETSc feature that could
> > interesting for
> > some users. In our lagrangian particle tracking it is neccessary to
> > send the
> > particle data to some specific processor - the new particle "master
> > processor" which performs the evaluation of the equations of motion
> > for this
> > particle.
> > In general we can do this with the MPI_isend, MPI_irecv routines.
> > In the PETSc environment this may be realized by an MPI_vector
> Do you mean a PETSc vector of type VECMPI, that is a parallel Vec?
> > with different
> > numer of entrys on each processor. The entrys of this MPI_vector may
> > be
> > adressed by its index and the rank of the processor where you wish
> > to set
> > the value.
> Do you mean something like
> VecSetValues(vec,n,ranks,localindices,values)
> where ranks[n], localindices[n], values[n]? Much like VecSetValues()
> with the "global indices"
> replaced with ranks,localindices?
> Or do you want something more like a VecScatter operation where the
> "global indices"
> are replaced with ranks,localindices
> Barry
> > Perhaps it is possible to realize this feature in following petsc
> > releases.
> > Best regards,
> > Tobias
> > Am Samstag 02 Februar 2008 schrieben Sie:
> >> Tobias,
> >> I have added DAGetNeighbors(). You will need to use petsc-dev
> >> see the developers
> >> page link from www.mcs.anl.gov/petsc
> >> Please let us know if you have any troubles.
> >> Barry
> >> On Feb 1, 2008, at 3:00 AM, Tobias Kempe wrote:
> >>> Hi PETSc team,
> >>> we are using distributed arrays for the communication of the
> >>> processors in our
> >>> domain decomposition. Nomally the user dont has to worry obout the
> >>> rank of
> >>> the neighboring processors. Now we wont to compute large amounts
> of
> >>> particles
> >>> in viscous fluids. The problem is when a particle leaves the
> >>> physical
> >>> domain, an other processer becomes the "master" of this particle.
> >>> With the
> >>> backround of this lagrangian particle tracking it becomes
> neccesarry
> >>> to
> >>> determine the ranks of the neighboring processors in order to send
> >>> particle
> >>> specific data to this processors.
> >>> Is there some PETSc routine to dertermine the rank of the
> >>> neighboring
> >>> processors in the east, west, front ..... and so on?
> >>> Thank you very much.
> >>> Best regards
> >>> Tobias Kempe
> >>> Dipl.-Ing. Tobias Kempe
> >>> Technische Universit?? Dresden
> >>> Institut f?? Str??ungsmechanik
> >>> Tel.: 0351-46336651
> >>> Fax: 0351-46335246
> >>> E-Mail: tobias.kempe at ism.mw.tu-dresden.de
> > Tel.: 0351-46336651
> > Fax: 0351-46335246
> Looking for last minute shopping deals? Find them fast with Yahoo!
> Search.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20080207/2d9aba1a/attachment.html>
