Native Windows port of PETSc library - not cygwin based.
Girish Pillai giri_pillai_99 at yahoo.com
Tue Mar 28 20:48:00 CST 2006
Hi Satish,
Somehow I thought it was the Gnu compilers that were
being used for the Windows port done with the help of
cygwin. So I think I was wrong in making that
assumption.
So what I really want is to build it with the
MS-VisualC++ compiler and Intel Fortran Compiler. So
cygwin is just used for the build purpose and the GNU
compilers never get used. Is that correct?
Thanks much,
Girish
--- Satish Balay <balay at mcs.anl.gov> wrote:
> yes - PETSc can be installed with
> MS-C/Compaq-Fortran [or intel
> compilers] on windows.
> However the build system still requires cygwin to
> build the PETSc
> libraries.
> Check the installation instructions for additional
> info. If you
> encounter problems - send us the erros with
> appropriate logfiles to
> petsc-maint at mcs.anl.gov
> [If configure doesn't work - send us configure.log]
> Satish
> On Tue, 28 Mar 2006, Girish Pillai wrote:
> > Folks,
> > Is there a port of PETSc library on Windows
> platform.
> > I am looking for native Windows port, not the
> cygwin
> > port.
> > Can one of you please respond?
> > The config script does not work properly for
> Windows
> > when I tried to run it.
> > Thanks,
> > Girish
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam?  Yahoo! Mail has the best spam
> protection around
> > http://mail.yahoo.com
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
