Native Windows port of PETSc library - not cygwin based.
Tue Mar 28 21:00:47 CST 2006
Petsc can also be used from gnu compilers. You need to specify the
correct compilers you wish to use to PETSc configure
I presume you would like to use PETSc from fortran [using intel
fortran] on windows? If so:
- install cygwin [for build tools per installation instructons]
- install MLK for blas/lapack [if available or use configure option --download-f-blas-lapack=1]
- install MPICH for windows [or if you wish to use PETSc sequentially, use --with-mpi=0]
Now counfigure PETSc with the required compilers [check config/cygwin-ms.py]
./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
[autodetect mpich & mlk from default locations]
BTW: We test with compaq fortran - and haven't tested with intel
fortran on windows for a while. If you encounter problems - let us
know.
Satish
On Tue, 28 Mar 2006, Girish Pillai wrote:
> Hi Satish,
> Somehow I thought it was the Gnu compilers that were
> being used for the Windows port done with the help of
> cygwin. So I think I was wrong in making that
> assumption.
> So what I really want is to build it with the
> MS-VisualC++ compiler and Intel Fortran Compiler. So
> cygwin is just used for the build purpose and the GNU
> compilers never get used. Is that correct?
> Thanks much,
> Regards,
> Girish
> --- Satish Balay <balay at mcs.anl.gov> wrote:
> > yes - PETSc can be installed with
> > MS-C/Compaq-Fortran [or intel
> > compilers] on windows.
> > However the build system still requires cygwin to
> > build the PETSc
> > libraries.
> > Check the installation instructions for additional
> > info. If you
> > encounter problems - send us the erros with
> > appropriate logfiles to
> > petsc-maint at mcs.anl.gov
> > [If configure doesn't work - send us configure.log]
> > Satish
> > > Folks,
> > > Is there a port of PETSc library on Windows
> > platform.
> > > I am looking for native Windows port, not the
> > cygwin
> > > port.
> > > Can one of you please respond?
> > > The config script does not work properly for
> > Windows
> > > when I tried to run it.
> > > Thanks,
> > > Girish
> > > __________________________________________________
> > > Do You Yahoo!?
> > > Tired of spam?  Yahoo! Mail has the best spam
> > protection around
> > > http://mail.yahoo.com
> Do You Yahoo!?
> Tired of spam?  Yahoo! Mail has the best spam protection around
