Adding Harwell-Boeing support in PETSc?
Hong Zhang hzhang at mcs.anl.gov
Tue Apr 5 13:41:10 CDT 2005
Victor and Richard,
The files mm2petsc.c, mmio.c and mmio.h are attached.
I just update it with petsc-dev (petsc-2.2.1 should be fine).
Let me know if you see problem/bug.
If you further improve it, please give me your improvement as well.
Hong
On Tue, 5 Apr 2005, Victor Eijkhout wrote:
> At 10:32 AM -0500 4/5/05, Hong Zhang wrote:
> >We have code that read MatrixMarket format, and write
> >into a petsc binary file. Then you can use petsc MatLoad()
> >for viewing or computation.
> I'm interested in this too. I wrote my own version. Maybe a good idea
> to add this to the petsc distribution?
> Victor Eijkhout <eijkhout at cs.utk.edu>, 329 Claxton, Comp Sci, UT,
> Knoxville TN 37996.
> tel: 865 974 9308 (W), 865 673 6998 (H), 865 974 8296 (F)
> http://www.cs.utk.edu/~eijkhout/
Type: text/x-csrc
Desc: mm2petsc.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20050405/a51590ef/attachment.bin>
Type: text/x-csrc
Desc: mmio.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20050405/a51590ef/attachment-0001.bin>
Type: text/x-chdr
Desc: mmio.h
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20050405/a51590ef/attachment-0002.bin>
