Adding Harwell-Boeing support in PETSc?
Victor Eijkhout eijkhout at cs.utk.edu
Wed Apr 6 23:08:40 CDT 2005
At 1:41 PM -0500 4/5/05, Hong Zhang wrote:
>The files mm2petsc.c, mmio.c and mmio.h are attached.
Years ago I found a couple of bugs in mmio.c and reported them to
Roldan Pozo. Apparently they haven't been fixed. The good boy is too
busy with other things.
Victor Eijkhout <eijkhout at cs.utk.edu>, 329 Claxton, Comp Sci, UT,
Knoxville TN 37996.
tel: 865 974 9308 (W), 865 673 6998 (H), 865 974 8296 (F)
http://www.cs.utk.edu/~eijkhout/
Type: application/applefile
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20050407/e3a4d146/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20050407/e3a4d146/attachment.obj>
