error in pnetcdf.inc
Jim Edwards jedwards at ucar.edu
Fri Jun 5 07:31:09 CDT 2015
The construct _I8 is part of the f90 standard and not f77.   I think that
for f77 compliance you would need to remove this modifier and set the
constant without it.
On Fri, Jun 5, 2015 at 3:17 AM, Wei-keng Liao <wkliao at eecs.northwestern.edu>
wrote:
> Hi, Jim
> Sorry for replying your email this late.
> I honestly do not have a good solution for this.
> If I removed the trailing underscore and 8, then the F77 program,
> pnf_test.f, is compiled fine with pg77 but failed with gfortran.
> Adding "-fno-range-check" flag to gfortran command line passed
> the compilation, but I don't think I should enforce this option for
> gfortran.
> On the other hand, pgf77 does not appear to understand the trailing suffix
> "_8".
> I am open to any suggestion.
> Wei-keng
> On Jun 2, 2015, at 12:25 PM, Jim Edwards wrote:
> > Sorry - I was wrong _I8 still gives an error.   The problem is that you
> are compiling an f90 test with f77 :
> > /usr/mpi/pgi/mvapich2-1.8.1-qlc/bin/mpif77 -c -g   -I../../src/lib
> -I../../src/libf -I../../src/libf90 pnf_test.f
> > PGFTN-S-0034-Syntax error at or near identifier _8
> (../../src/libf/pnetcdf.inc: 79)
> (../../src/libf/pnetcdf.inc: 80)
> > PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 51)
> > PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 64)
> > PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 65)
> > PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 69)
> > switching this to use f90 solves the problem.
> > On Tue, Jun 2, 2015 at 10:28 AM, Jim Edwards <jedwards at ucar.edu> wrote:
> > Building pnetcdf1.6.1 using the pgi 15.1 compiler gives an error at
> lines 54 and 55 of pnetcdf.inc.   The compiler did not like:
> >      parameter (nf_fill_uint = 4294967295_8)
> >      parameter (nf_fill_int64 = -9223372036854775806_8)
> > I changed it to:
> >      parameter (nf_fill_uint = 4294967295_I8)
> >       parameter (nf_fill_int64 = -9223372036854775806_I8)
> > Jim Edwards
> > CESM Software Engineer
> > National Center for Atmospheric Research
> > Boulder, CO
> > Jim Edwards
> > Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150605/3384d473/attachment.html>
