error in pnetcdf.inc
Wei-keng Liao wkliao at eecs.northwestern.edu
Fri Jun 5 08:34:24 CDT 2015
If I remove the modifier "_8", then gfortran failed to compile.
Here is the test program I used.
% cat big_constants.f
      program Test
      implicit none
      integer*8  nf_fill_uint
      parameter (nf_fill_uint = 4294967295)
      end
% gfortran big_constants.f
big_constants.f:4.42:
                                          1
Error: Integer too big for its kind at (1). This check can be disabled with the option -fno-range-check
(Compiling the same above program with pgf77 is fine.)
Wei-keng
On Jun 5, 2015, at 7:31 AM, Jim Edwards wrote:
> The construct _I8 is part of the f90 standard and not f77.   I think that for f77 compliance you would need to remove this modifier and set the constant without it.
> On Fri, Jun 5, 2015 at 3:17 AM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
> Hi, Jim
> Sorry for replying your email this late.
> I honestly do not have a good solution for this.
> If I removed the trailing underscore and 8, then the F77 program,
> pnf_test.f, is compiled fine with pg77 but failed with gfortran.
> Adding "-fno-range-check" flag to gfortran command line passed
> the compilation, but I don't think I should enforce this option for gfortran.
> On the other hand, pgf77 does not appear to understand the trailing suffix "_8".
> I am open to any suggestion.
> Wei-keng
> On Jun 2, 2015, at 12:25 PM, Jim Edwards wrote:
> > Sorry - I was wrong _I8 still gives an error.   The problem is that you are compiling an f90 test with f77 :
> > /usr/mpi/pgi/mvapich2-1.8.1-qlc/bin/mpif77 -c -g   -I../../src/lib  -I../../src/libf -I../../src/libf90 pnf_test.f
> > PGFTN-S-0034-Syntax error at or near identifier _8 (../../src/libf/pnetcdf.inc: 79)
> > PGFTN-S-0034-Syntax error at or near identifier _8 (../../src/libf/pnetcdf.inc: 80)
> > PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 51)
> > PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 64)
> > PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 65)
> > PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 69)
> > switching this to use f90 solves the problem.
> > On Tue, Jun 2, 2015 at 10:28 AM, Jim Edwards <jedwards at ucar.edu> wrote:
> > Building pnetcdf1.6.1 using the pgi 15.1 compiler gives an error at lines 54 and 55 of pnetcdf.inc.   The compiler did not like:
> >      parameter (nf_fill_uint = 4294967295_8)
> >      parameter (nf_fill_int64 = -9223372036854775806_8)
> > I changed it to:
> >      parameter (nf_fill_uint = 4294967295_I8)
> >       parameter (nf_fill_int64 = -9223372036854775806_I8)
> > Jim Edwards
> > CESM Software Engineer
> > National Center for Atmospheric Research
> > Boulder, CO
> > Jim Edwards
> > Boulder, CO
> Jim Edwards
> Boulder, CO
