error in pnetcdf.inc
Wei-keng Liao wkliao at eecs.northwestern.edu
Fri Jun 5 04:17:20 CDT 2015
Hi, Jim
Sorry for replying your email this late.
I honestly do not have a good solution for this.
If I removed the trailing underscore and 8, then the F77 program,
pnf_test.f, is compiled fine with pg77 but failed with gfortran.
Adding "-fno-range-check" flag to gfortran command line passed
the compilation, but I don't think I should enforce this option for gfortran.
On the other hand, pgf77 does not appear to understand the trailing suffix "_8".
I am open to any suggestion.
Wei-keng
On Jun 2, 2015, at 12:25 PM, Jim Edwards wrote:
> Sorry - I was wrong _I8 still gives an error.   The problem is that you are compiling an f90 test with f77 :
> /usr/mpi/pgi/mvapich2-1.8.1-qlc/bin/mpif77 -c -g   -I../../src/lib  -I../../src/libf -I../../src/libf90 pnf_test.f
> PGFTN-S-0034-Syntax error at or near identifier _8 (../../src/libf/pnetcdf.inc: 79)
> PGFTN-S-0034-Syntax error at or near identifier _8 (../../src/libf/pnetcdf.inc: 80)
> PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 51)
> PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 64)
> PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 65)
> PGFTN-S-0034-Syntax error at or near ( (pnf_test.f: 69)
> switching this to use f90 solves the problem.
> On Tue, Jun 2, 2015 at 10:28 AM, Jim Edwards <jedwards at ucar.edu> wrote:
> Building pnetcdf1.6.1 using the pgi 15.1 compiler gives an error at lines 54 and 55 of pnetcdf.inc.   The compiler did not like:
>      parameter (nf_fill_uint = 4294967295_8)
>      parameter (nf_fill_int64 = -9223372036854775806_8)
> I changed it to:
>      parameter (nf_fill_uint = 4294967295_I8)
>       parameter (nf_fill_int64 = -9223372036854775806_I8)
> Jim Edwards
> CESM Software Engineer
> National Center for Atmospheric Research
> Boulder, CO
> Jim Edwards
> Boulder, CO
