Trouble with too many '-W' flags from ./configure
Wei-keng Liao wkliao at ece.northwestern.edu
Wed May 1 17:04:42 CDT 2013
Hi, Giovanni,
Thanks for reporting this issue. This option of enabling strict is intended for GNU compiler only.
I have changed configure.in accordingly in r1207. The default is disable-strict.
best
Wei-keng
On May 1, 2013, at 12:32 PM, Giovanni A. Cone wrote:
> Hello parallel-netCDF maintainers:
>   I am in the process of building parallel-netCDF against all our provided compilers and related MPI library builds. I have encountered trouble with the PGI compiler not successfully building due to it not gracefully ignoring the plethora of "-W" flags that are set in the "configure.in" file around lines 80-82.  From my understanding of Autotools, that modification of the CFLAGS variable shouldn't even be happening if I pass the "--disable-strict" flag to the "./configure".  What I have in my ./configure invocation is:
> ./configure --prefix=$INST_PATH  --enable-largefile --with-mpi=$MPI_ROOT --disable-strict
> Note: env vars, CC, FC are properly set.
> However, it seems that either that the configure script is still modifying the CFLAGS to have all those "-W" flags, or there is something wrong with the "configure.in" script.
> I should note that builds against the Intel compilers (11.1.072 to 13.0.1) and GNU compilers (4.4.x to 4.7.2) all seem to happily ignore these irrelevant "-W" flags just fine.  I'm guessing PGI is just picky, and I'll submit a bug report to them as well.  However, there is something not quite right here
> that you should perhaps investigate.  I can work around this by doing the following in my build scripts:
> sed -i '80,82 s/^/dnl /' configure.in
> for the time being.
> Thank you for your consideration on this matter.
> !   Giovanni "Vann" Cone
> !   LANL HPC-3 Consultant
> !   TA-3, BLDG 2327, RM 1128
> !   Schedule B
> !   I fight for the users!
> END OF LINE
