Building errors relating to undefined reference of 'nfmpi_*'
Li Dong dongli at lasg.iap.ac.cn
Thu May 30 02:48:50 CDT 2013
Dear PnetCDF supporters,
When I build parallel-netcdf on our server, I invoked 'make tests' after 'make' and encountered the following errors:
/apps/intel/impi/4.0.2.003/intel64/bin/mpiifort -o bigrecords bigrecords.o -L../../src/lib  -lpnetcdf
bigrecords.o: In function `MAIN__':
bigrecords.F:(.text+0xb0): undefined reference to `nfmpi_create_'
bigrecords.F:(.text+0xe6): undefined reference to `nfmpi_def_dim_'
bigrecords.F:(.text+0x12b): undefined reference to `nfmpi_def_dim_'
bigrecords.F:(.text+0x170): undefined reference to `nfmpi_def_dim_'
bigrecords.F:(.text+0x1c2): undefined reference to `nfmpi_def_var_'
bigrecords.F:(.text+0x214): undefined reference to `nfmpi_def_var_'
bigrecords.F:(.text+0x282): undefined reference to `nfmpi_def_var_'
bigrecords.F:(.text+0x2d3): undefined reference to `nfmpi_put_att_text_'
bigrecords.F:(.text+0x324): undefined reference to `nfmpi_put_att_text_'
bigrecords.F:(.text+0x375): undefined reference to `nfmpi_put_att_text_'
bigrecords.F:(.text+0x3c6): undefined reference to `nfmpi_put_att_text_'
bigrecords.F:(.text+0x417): undefined reference to `nfmpi_put_att_text_'
bigrecords.o:bigrecords.F:(.text+0x468): more undefined references to `nfmpi_put_att_text_' follow
bigrecords.F:(.text+0x486): undefined reference to `nfmpi_enddef_'
bigrecords.F:(.text+0x4d2): undefined reference to `nfmpi_put_vara_real_all_'
bigrecords.F:(.text+0x557): undefined reference to `nfmpi_put_vara_double_all_'
bigrecords.F:(.text+0x57e): undefined reference to `nfmpi_close_'
bigrecords.F:(.text+0x5c2): undefined reference to `nfmpi_open_'
bigrecords.F:(.text+0x5f2): undefined reference to `nfmpi_inq_varid_'
bigrecords.F:(.text+0x63e): undefined reference to `nfmpi_get_vara_double_all_'
bigrecords.F:(.text+0x65c): undefined reference to `nfmpi_close_'
bigrecords.o: In function `writerecs_':
bigrecords.F:(.text+0x1165): undefined reference to `nfmpi_put_vara_double_all_'
../../src/lib/libpnetcdf.a(strerrorf.o): In function `nfmpi_strerror_':
strerrorf.f:(.text+0x15): undefined reference to `nfmpi_xstrerror_'
make[2]: *** [bigrecords] Error 1
The config.log file is in the attach and the results of 'uname -a' are:
Linux ln1 2.6.18-194.17.1.0.1.el5_lustre.1.8.5 #1 SMP Wed Aug 3 18:09:09 CST 2011 x86_64 x86_64 x86_64 GNU/Linux
How to solve this problem? Thanks in advance!
Best regards,
Li
Dr. Li Dong (董理)
LASG, Institute of Atmospheric Physics
Chinese Academy of Sciences
P.O. Box 9804
Beijing 100029, China
Phone: 8610-8299 5143
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130530/184cccc0/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130530/184cccc0/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20130530/184cccc0/attachment-0003.html>
