pnetcdf 1.2.0 create file issue
David Knaak knaak at cray.com
Fri May 11 11:46:25 CDT 2012
Jim,
Since you are having this problem on a Cray system, please open a Cray
bug report against MPI and I will look at it.  We can take further
discussions off line.
Thanks.
David
On Fri, May 11, 2012 at 10:03:28AM -0600, Jim Edwards wrote:
> On Fri, May 11, 2012 at 9:43 AM, Rob Latham <robl at mcs.anl.gov> wrote:
>     On Thu, May 10, 2012 at 03:28:57PM -0600, Jim Edwards wrote:
>     > This occurs on the ncsa machine bluewaters.   I am using pnetcdf1.2.0 and
>     > pgi 11.10.0
>     need one more bit of information: the version of MPT you are using.
> Sorry, what's mpt?  MPI?
> Currently Loaded Modulefiles:
>   1) modules/3.2.6.6                       9)
> user-paths                           17) xpmem/0.1-2.0400.31280.3.1.gem
>   2) xtpe-network-gemini                  10) pgi/
> 11.10.0                          18) xe-sysroot/4.0.46
>   3) xt-mpich2/5.4.2                      11) xt-libsci/
> 11.0.04                    19) xt-asyncpe/5.07
>   4) xtpe-interlagos                      12) udreg/
> 2.3.1-1.0400.4264.3.1.gem      20) atp/1.4.1
>   5) eswrap/1.0.12                        13) ugni/
> 2.3-1.0400.4374.4.88.gem        21) PrgEnv-pgi/4.0.46
>   6) torque/2.5.10                        14) pmi/
> 3.0.0-1.0000.8661.28.2807.gem    22) hdf5-parallel/1.8.7
>   7) moab/6.1.5                           15) dmapp/
> 3.2.1-1.0400.4255.2.159.gem    23) netcdf-hdf5parallel/4.1.3
>   8) scripts                              16) gni-headers/
> 2.1-1.0400.4351.3.1.gem  24) parallel-netcdf/1.2.0
>     > The issue is that calling nfmpi_createfile would sometimes result in an
>     > error:
>     > MPI_File_open : Other I/O error , error stack:
>     > (unknown)(): Other I/O error
>     > 126: MPI_File_open : Other I/O error , error stack:
>     >   Error on create :           502          -32
>     > The error appears to be intermittent and I could not get it to occur at
>     all
>     > on a small number of tasks (160) but it occurs with high frequency when
>     > using a larger number of tasks (>=1600).    I traced the problem to the
>     use
>     > of nf_clobber in the mode argument, removing the nf_clobber seems to have
>     > solved the problem and I think that create implies clobber anyway doesn't
>     > it?
>     > Can someone who knows what is going on under the covers enlighten me
>     > with some understanding of this issue?   I suspect that one task is
>     trying
>     > to clobber the file that another has just created or something of that
>     > nature.
>     Unfortunately, "under the covers" here means "inside the MPI-IO
>     library", which we don't have access to.
>     in the create case we call MPI_File_open with "MPI_MODE_RDWR |
>     MPI_MODE_CREATE", and  if noclobber set, we add MPI_MODE_EXCL.
>     OK, so that's pnetcdf.  What's going on in MPI-IO?  Well, cray's based
>     their MPI-IO off of our ROMIO, but I'm not sure which version.
>     Let me cook up a quick MPI-IO-only test case you can run to trigger
>     this problem and then you can beat cray over the head with it.
> Sounds good, thanks.
>     ==rob
>     Rob Latham
>     Mathematics and Computer Science Division
>     Argonne National Lab, IL USA
> Jim Edwards
> CESM Software Engineering Group
> National Center for Atmospheric Research
> Boulder, CO
> 303-497-1842
