pnetcdf 1.2.0 create file issue
Rob Latham robl at mcs.anl.gov
Fri May 11 12:54:39 CDT 2012
On Fri, May 11, 2012 at 11:46:25AM -0500, David Knaak wrote:
> Jim,
> Since you are having this problem on a Cray system, please open a Cray
> bug report against MPI and I will look at it.  We can take further
> discussions off line.
Oh, howdy David! forgot you were on the list.  Thanks for keeping an
eye on things.
the pnetcdf list is pretty low-traffic these days, but we have an
awful lot of users in a cray and Lustre environment.   If you'd rather
discuss cray specific stuff elsewhere, I'd understand, but please let
us know what you figure out.
==rob
> Thanks.
> David
> On Fri, May 11, 2012 at 10:03:28AM -0600, Jim Edwards wrote:
> > On Fri, May 11, 2012 at 9:43 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> >     On Thu, May 10, 2012 at 03:28:57PM -0600, Jim Edwards wrote:
> >     > This occurs on the ncsa machine bluewaters.   I am using pnetcdf1.2.0 and
> >     > pgi 11.10.0
> >     need one more bit of information: the version of MPT you are using.
> > Sorry, what's mpt?  MPI?
> > Currently Loaded Modulefiles:
> >   1) modules/3.2.6.6                       9)
> > user-paths                           17) xpmem/0.1-2.0400.31280.3.1.gem
> >   2) xtpe-network-gemini                  10) pgi/
> > 11.10.0                          18) xe-sysroot/4.0.46
> >   3) xt-mpich2/5.4.2                      11) xt-libsci/
> > 11.0.04                    19) xt-asyncpe/5.07
> >   4) xtpe-interlagos                      12) udreg/
> > 2.3.1-1.0400.4264.3.1.gem      20) atp/1.4.1
> >   5) eswrap/1.0.12                        13) ugni/
> > 2.3-1.0400.4374.4.88.gem        21) PrgEnv-pgi/4.0.46
> >   6) torque/2.5.10                        14) pmi/
> > 3.0.0-1.0000.8661.28.2807.gem    22) hdf5-parallel/1.8.7
> >   7) moab/6.1.5                           15) dmapp/
> > 3.2.1-1.0400.4255.2.159.gem    23) netcdf-hdf5parallel/4.1.3
> >   8) scripts                              16) gni-headers/
> > 2.1-1.0400.4351.3.1.gem  24) parallel-netcdf/1.2.0
> >     > The issue is that calling nfmpi_createfile would sometimes result in an
> >     > error:
> >     > MPI_File_open : Other I/O error , error stack:
> >     > (unknown)(): Other I/O error
> >     > 126: MPI_File_open : Other I/O error , error stack:
> >     >   Error on create :           502          -32
> >     > The error appears to be intermittent and I could not get it to occur at
> >     all
> >     > on a small number of tasks (160) but it occurs with high frequency when
> >     > using a larger number of tasks (>=1600).    I traced the problem to the
> >     use
> >     > of nf_clobber in the mode argument, removing the nf_clobber seems to have
> >     > solved the problem and I think that create implies clobber anyway doesn't
> >     > it?
> >     > Can someone who knows what is going on under the covers enlighten me
> >     > with some understanding of this issue?   I suspect that one task is
> >     trying
> >     > to clobber the file that another has just created or something of that
> >     > nature.
> >     Unfortunately, "under the covers" here means "inside the MPI-IO
> >     library", which we don't have access to.
> >     in the create case we call MPI_File_open with "MPI_MODE_RDWR |
> >     MPI_MODE_CREATE", and  if noclobber set, we add MPI_MODE_EXCL.
> >     OK, so that's pnetcdf.  What's going on in MPI-IO?  Well, cray's based
> >     their MPI-IO off of our ROMIO, but I'm not sure which version.
> >     Let me cook up a quick MPI-IO-only test case you can run to trigger
> >     this problem and then you can beat cray over the head with it.
> > Sounds good, thanks.
> >     ==rob
> >     Rob Latham
> >     Mathematics and Computer Science Division
> >     Argonne National Lab, IL USA
> > Jim Edwards
> > CESM Software Engineering Group
> > National Center for Atmospheric Research
> > Boulder, CO
> > 303-497-1842
Rob Latham
