pnetcdf 1.2.0 create file issue
Jim Edwards jedwards at ucar.edu
Fri May 11 11:03:28 CDT 2012
On Fri, May 11, 2012 at 9:43 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Thu, May 10, 2012 at 03:28:57PM -0600, Jim Edwards wrote:
> > This occurs on the ncsa machine bluewaters.   I am using pnetcdf1.2.0 and
> > pgi 11.10.0
> need one more bit of information: the version of MPT you are using.
> Sorry, what's mpt?  MPI?
Currently Loaded Modulefiles:
  1) modules/3.2.6.6                       9)
user-paths                           17) xpmem/0.1-2.0400.31280.3.1.gem
  2) xtpe-network-gemini                  10)
pgi/11.10.0                          18) xe-sysroot/4.0.46
  3) xt-mpich2/5.4.2                      11)
xt-libsci/11.0.04                    19) xt-asyncpe/5.07
  4) xtpe-interlagos                      12)
udreg/2.3.1-1.0400.4264.3.1.gem      20) atp/1.4.1
  5) eswrap/1.0.12                        13)
ugni/2.3-1.0400.4374.4.88.gem        21) PrgEnv-pgi/4.0.46
  6) torque/2.5.10                        14)
pmi/3.0.0-1.0000.8661.28.2807.gem    22) hdf5-parallel/1.8.7
  7) moab/6.1.5                           15)
dmapp/3.2.1-1.0400.4255.2.159.gem    23) netcdf-hdf5parallel/4.1.3
  8) scripts                              16)
gni-headers/2.1-1.0400.4351.3.1.gem  24) parallel-netcdf/1.2.0
> > The issue is that calling nfmpi_createfile would sometimes result in an
> > error:
> > MPI_File_open : Other I/O error , error stack:
> > (unknown)(): Other I/O error
> > 126: MPI_File_open : Other I/O error , error stack:
> >   Error on create :           502          -32
> > The error appears to be intermittent and I could not get it to occur at
> all
> > on a small number of tasks (160) but it occurs with high frequency when
> > using a larger number of tasks (>=1600).    I traced the problem to the
> use
> > of nf_clobber in the mode argument, removing the nf_clobber seems to have
> > solved the problem and I think that create implies clobber anyway doesn't
> > it?
> > Can someone who knows what is going on under the covers enlighten me
> > with some understanding of this issue?   I suspect that one task is
> trying
> > to clobber the file that another has just created or something of that
> > nature.
> Unfortunately, "under the covers" here means "inside the MPI-IO
> library", which we don't have access to.
> in the create case we call MPI_File_open with "MPI_MODE_RDWR |
> MPI_MODE_CREATE", and  if noclobber set, we add MPI_MODE_EXCL.
> OK, so that's pnetcdf.  What's going on in MPI-IO?  Well, cray's based
> their MPI-IO off of our ROMIO, but I'm not sure which version.
> Let me cook up a quick MPI-IO-only test case you can run to trigger
> this problem and then you can beat cray over the head with it.
Sounds good, thanks.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
Jim Edwards
CESM Software Engineering Group
National Center for Atmospheric Research
Boulder, CO
303-497-1842
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20120511/c70d7fd3/attachment.htm>
