problem with nfmpi_iput_vara_double
Kui Gao kgao at eecs.northwestern.edu
Fri Nov 19 22:32:51 CST 2010
Hi Jim,
	You are right. The iobuf can not be reused if wait_all() is not called.
	Best regards,
Kui.
On Nov 19, 2010, at 6:33 PM, Jim Edwards wrote:
> I think its operator error.  Reusing the iobuf before the write is completed.  Thanks
> fat fingered on a virtual keyboard
>> On Nov 19, 2010 5:21 PM, "Kui Gao" <kgao at eecs.northwestern.edu> wrote:
>> Hi Jim,
>>        Thank you for report the problem. Could you please send me the test code? I'd like to test it.
>>        Thanks,
>> Kui.
>> On Nov 19, 2010, at 3:28 PM, Jim Edwards wrote:
>> I'm trying out the async interface and running into problems.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20101119/49fcf6b9/attachment.htm>
