problem with nfmpi_iput_vara_double
Wei-keng Liao wkliao at ece.northwestern.edu
Sat Nov 20 11:05:55 CST 2010
Just for the record, this issue has been solved.
Wei-keng
Begin forwarded message:
> From: Kui Gao <kgao at eecs.northwestern.edu>
> Date: November 19, 2010 10:06:24 PM CST
> To: Jim Edwards <jedwards at ucar.edu>
> Cc: Wei-keng Liao <wkliao at ece.northwestern.edu>
> Subject: Re: problem with nfmpi_iput_vara_double
> Hi Jim,
> 	you are right. The iobuf can not be reused if wait_all() is not called.
> 	Best regards,
> Kui.
> On Nov 19, 2010, at 6:33 PM, Jim Edwards wrote:
>> I think its operator error.  Reusing the iobuf before the write is completed.  Thanks
>> fat fingered on a virtual keyboard
>>> On Nov 19, 2010 5:21 PM, "Kui Gao" <kgao at eecs.northwestern.edu> wrote:
>>> Hi Jim,
>>>        Thank you for report the problem. Could you please send me the test code? I'd like to test it.
>>>        Thanks,
>>> Kui.
>>> On Nov 19, 2010, at 3:28 PM, Jim Edwards wrote:
>>> > I'm trying out the async interface and running ...
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20101120/c73ab38c/attachment.htm>
