pnetcdf with WRF
Lev Lafayette lev at vpac.org
Sun Nov 21 23:45:00 CST 2010
Hi everyone,
I am attempting to install WRF (Weather Research and Forecasting) on a cluster using, as required and expected, pnetcdf.
No matter which openmpi and compilers I use (pgi, intel and gcc) I am receiving an error which is preventing a successful compilation of WRF
i.e.,
strerrorf.f:(.text+0x2c): undefined reference to `nfmpi_xstrerror_'
/usr/local/pnetcdf/1.2.0-pgi/lib/libpnetcdf.a(inq_libversf.o): In function `nfmpi_inq_libvers_':
inq_libversf.f:(.text+0x21): undefined reference to `nfmpi_xinq_libvers_'
/usr/local/pnetcdf/1.2.0-intel/lib/libpnetcdf.a(strerrorf.o): In function `nfmpi_strerror_':
/usr/local/pnetcdf/1.2.0-gcc/lib/libpnetcdf.a(strerrorf.o): In function `nfmpi_strerror_':
collect2: ld returned 1 exit status
Given the install of pnetcdf is pretty trivial, I was wondering what trivial component I've overlooked for this error to arise..
Thanks in advance,
Lev Lafayette, Systems Administrator, Victorian Partnership for Advanced Computing, lev at vpac.org
"If you are sending a reply to a message or a posting be sure you summarize the original at the top of the message, or include just enough text of the original to give a context. This will make sure readers understand when they start to read your response."  RFC 1855
110 Victoria Street                                        phone:   03 9925 4909
Carlton South, Victoria 3053,  Australia          mobile:  0432 255 208
