Serial build on MacOSX?
Wei-keng Liao wkliao at ece.northwestern.edu
Thu Jan 28 14:23:39 CST 2010
pnetcdf replies on MPI compilers. GCC would not build it.
Please set the following environment variables before run configure.
setenv CC     mpicc
setenv FC     mpif77
setenv F90    mpif90
setenv MPICC  mpicc
setenv MPIF77 mpif77
setenv MPIF90 mpif90
Wei-keng
On Jan 28, 2010, at 2:13 PM, John Michalakes wrote:
> Is it possible to build parallel-netcdf in serial mode on a
> workstation, in this case a dual-quad Intel Mac OS X 10.5.8 system
> with MPICH 1.0.8?  The configure script is failing here:
> checking size of MPI_Offset... ./configure line 11386: -c: command
> not found
> Whole config.log attached.  I want to do some serial development on
> this workstation first, then move over to the big cluster once I've
> got it working with one task.
> Thanks,
> John
> John Michalakes, Software Engineer        michalak at ucar.edu
> NCAR, MMM Division                   voice: +1 303 497 8199
> 3450 Mitchell Lane                     fax: +1 303 497 8181
> Boulder, Colorado 80301 U.S.A.        cell: +1 720 209 2320
>         http://www.mmm.ucar.edu/individual/michalakes
> <config.log>
