Serial build on MacOSX?
John Michalakes john at michalakes.us
Thu Jan 28 14:28:04 CST 2010
That did it. Configure worked.  Making now.  Thanks!
On 1/28/2010 1:23 PM, Wei-keng Liao wrote:
> pnetcdf replies on MPI compilers. GCC would not build it.
> Please set the following environment variables before run configure.
> setenv CC     mpicc
> setenv FC     mpif77
> setenv F90    mpif90
> setenv MPICC  mpicc
> setenv MPIF77 mpif77
> setenv MPIF90 mpif90
> Wei-keng
> On Jan 28, 2010, at 2:13 PM, John Michalakes wrote:
>> Is it possible to build parallel-netcdf in serial mode on a
>> workstation, in this case a dual-quad Intel Mac OS X 10.5.8 system
>> with MPICH 1.0.8?  The configure script is failing here:
>> checking size of MPI_Offset... ./configure line 11386: -c: command
>> not found
>> Whole config.log attached.  I want to do some serial development on
>> this workstation first, then move over to the big cluster once I've
>> got it working with one task.
>> Thanks,
>> John
>> John Michalakes, Software Engineer        michalak at ucar.edu
>> NCAR, MMM Division                   voice: +1 303 497 8199
>> 3450 Mitchell Lane                     fax: +1 303 497 8181
>> Boulder, Colorado 80301 U.S.A.        cell: +1 720 209 2320
>>         http://www.mmm.ucar.edu/individual/michalakes
>> <config.log>
