parallel-netcdf-1.1.1 released
Don Morton Don.Morton at alaska.edu
Wed Jan 27 18:13:25 CST 2010
On Wed, Jan 27, 2010 at 11:57 PM, Don Morton <Don.Morton at alaska.edu> wrote:
> Okie dokie, I don't know what the root cause is (yet), but it appears that
> the macros.make (generated by ./configure?) had set the F90 macro to blank,
> so I just went in and changed it to "ftn" and make install now works.
Just for the heck of it, I tried setting an F90 environment variable before
running ./configure, but the resulting macros.make still had a blank for the
F90 macro...  So, "maybe" this is getting to the root of the problem?
Arctic Region Supercomputing Center
http://www.arsc.edu/~morton/
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20100128/ca4e2c48/attachment.htm>
