Having a compile issue
Joe Buck jbbuck at gmail.com
Wed Dec 9 14:11:11 CST 2009
Wei-keng,
I had the source in /git/parallel-netcdf/ and had created a directory in
/tmp/pnetcdf. I'd run "/git/parallel-netcdf/configure" in the /tmp/pnetcdf
directory so that I could do all the building in there and not worry about
having left over build-related "cruft" in the /git/parallel-netcdf
directory.
That being said, I really appreciate your help and I tried what you
suggested (building in the source directory) and saw the same error. I'm
attaching the output of the "make tests" compilation. The error now comes
from "./pnctestf.F" as you suggested it should.
-Joe Buck
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20091209/5b26428e/attachment.htm>
make[1]: Entering directory `/git/parallel-netcdf/test'
set -e; for i in common test_double test_double_int test_float test_int test_dtype nc_test fandc nf_test largefile C mcoll_perf mcoll_fortran test_check_header testcases; do ( cd $i && make ; ) ; done
make[2]: Entering directory `/git/parallel-netcdf/test/common'
/install/mpich2-121/bin/mpicc -g   -c -o testutils.o testutils.c
ar cru libtestutils.a testutils.o
make[2]: Leaving directory `/git/parallel-netcdf/test/common'
make[2]: Entering directory `/git/parallel-netcdf/test/test_double'
/install/mpich2-121/bin/mpicc -g -I./../../src/lib -I./../common  -c test_read.c
/install/mpich2-121/bin/mpicc -o test_read test_read.o -L../../src/lib -L../common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I./../../src/lib -I./../common  -c test_read_indep.c
/install/mpich2-121/bin/mpicc -o test_read_indep test_read_indep.o -L../../src/lib -L../common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I./../../src/lib -I./../common  -c test_write.c
/install/mpich2-121/bin/mpicc -o test_write test_write.o -L../../src/lib -L../common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I./../../src/lib -I./../common  -c test_write_indep.c
/install/mpich2-121/bin/mpicc -o test_write_indep test_write_indep.o -L../../src/lib -L../common  -lpnetcdf -ltestutils
make[2]: Leaving directory `/git/parallel-netcdf/test/test_double'
make[2]: Entering directory `/git/parallel-netcdf/test/test_double_int'
make[2]: Leaving directory `/git/parallel-netcdf/test/test_double_int'
make[2]: Entering directory `/git/parallel-netcdf/test/test_float'
/install/mpich2-121/bin/mpicc -o test_read test_read.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -o test_read_indep test_read_indep.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -o test_write test_write.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -o test_write_indep test_write_indep.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
make[2]: Leaving directory `/git/parallel-netcdf/test/test_float'
make[2]: Entering directory `/git/parallel-netcdf/test/test_int'
/install/mpich2-121/bin/mpicc -g -I./../../src/lib -I./../common  -c test_write64.c
/install/mpich2-121/bin/mpicc -o test_write64 test_write64.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
/install/mpich2-121/bin/mpicc -g -I./../../src/lib -I./../common  -c test_read64.c
/install/mpich2-121/bin/mpicc -o test_read64 test_read64.o -L../../src/lib -L..//common  -lpnetcdf -ltestutils
make[2]: Leaving directory `/git/parallel-netcdf/test/test_int'
make[2]: Entering directory `/git/parallel-netcdf/test/test_dtype'
/install/mpich2-121/bin/mpicc -g -I./../../src/lib  -c test_subarray.c
/install/mpich2-121/bin/mpicc -o test_subarray test_subarray.o -L../../src/lib  -lpnetcdf
/install/mpich2-121/bin/mpicc -g -I./../../src/lib  -c test_darray.c
/install/mpich2-121/bin/mpicc -o test_darray test_darray.o -L../../src/lib  -lpnetcdf
/install/mpich2-121/bin/mpicc -g -I./../../src/lib  -c test_nonblocking.c
/install/mpich2-121/bin/mpicc -o test_nonblocking test_nonblocking.o -L../../src/lib  -lpnetcdf
make[2]: Leaving directory `/git/parallel-netcdf/test/test_dtype'
make[2]: Entering directory `/git/parallel-netcdf/test/nc_test'
/install/mpich2-121/bin/mpicc -c -g -I./../../src/lib -I.   nc_test.c
/install/mpich2-121/bin/mpicc -c -g -I./../../src/lib -I.   error.c
/install/mpich2-121/bin/mpicc -c -g -I./../../src/lib -I.   test_get.c
/install/mpich2-121/bin/mpicc -c -g -I./../../src/lib -I.   test_put.c
/install/mpich2-121/bin/mpicc -c -g -I./../../src/lib -I.   test_read.c
/install/mpich2-121/bin/mpicc -c -g -I./../../src/lib -I.   test_write.c
/install/mpich2-121/bin/mpicc -c -g -I./../../src/lib -I.   util.c
/install/mpich2-121/bin/mpicc -o nc_test -g  nc_test.o error.o test_get.o test_put.o test_read.o test_write.o util.o -L../../src/lib -lpnetcdf -lm
make[2]: Leaving directory `/git/parallel-netcdf/test/nc_test'
make[2]: Entering directory `/git/parallel-netcdf/test/fandc'
mpif77 -o pnctestf -g  -o pnctestf ./pnctestf.F -I../../src/libf/ -L../../src/lib -lpnetcdf -lm
   MAIN pnf_test:
Warning on line 78 of <stdin>: ignoring text after "end".
Warning on line 78 of <stdin>: local variable nf_request never used
Warning on line 1 of <stdin>: nfmpi_get_varm_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_nvars declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_natts declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_comm_null_delete_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_type_null_delete_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_rename_dim declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_dimlen declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_rename_att declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_rename_var declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_attlen declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_null_copy_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_set_default_format declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_wtick declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_wtime declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_dimname declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_attname declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_varname declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_libvers declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_atttype declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_vartype declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_dup_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_open declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_wait declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: pmpi_wtick declared EXTERNAL but never used.
Warning on line 1 of <stdin>: pmpi_wtime declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_sync declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_null_delete_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_vardimid declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_unlimdim declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_varndims declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_varnatts declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_double_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_redef declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_abort declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_file_info declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iget_vara_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_iput_vara_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int2 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_real declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_delete declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_text declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_end_indep_data declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_att_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_att_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_win_null_copy_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_del_att declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_dim declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_waitall declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_att declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_var declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_comm_null_copy_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_double declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_var1 declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_type_null_copy_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_begin_indep_data declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_set_fill declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_win_dup_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_copy_att declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_win_null_delete_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_var_text_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_strerror declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_issyserr declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_conversion_fn_null declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_varm_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vars_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_dimid declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_comm_dup_fn declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vara_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_attid declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_varid declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_varm_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_inq_ndims declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_get_vara_real_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int1_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: nfmpi_put_vars_int2_all declared EXTERNAL but never used.
Warning on line 1 of <stdin>: mpi_type_dup_fn declared EXTERNAL but never used.
./pnctestf.F: In function ?MAIN__?:
./pnctestf.F:34: error: expected ?=?, ?,?, ?;?, ?asm? or ?__attribute__? before ?totsiz_3d__?
./pnctestf.F:34: error: ?totsiz_3d__? undeclared (first use in this function)
./pnctestf.F:34: error: (Each undeclared identifier is reported only once
./pnctestf.F:34: error: for each function it appears in.)
./pnctestf.F:34: error: expected expression before ?{? token
./pnctestf.F:58: error: expected declaration specifiers or ?...? before ?longint?
<stdin>:49: warning: passing argument 4 of ?nfmpi_def_dim__? makes integer from pointer without a cast
./pnctestf.F:58: note: expected ?ftnlen? but argument is of type ?integer *?
<stdin>:49: error: too many arguments to function ?nfmpi_def_dim__?
<stdin>:52: warning: passing argument 4 of ?nfmpi_def_dim__? makes integer from pointer without a cast
<stdin>:52: error: too many arguments to function ?nfmpi_def_dim__?
<stdin>:54: warning: passing argument 4 of ?nfmpi_def_dim__? makes integer from pointer without a cast
<stdin>:54: error: too many arguments to function ?nfmpi_def_dim__?
/usr/bin/f77: aborting compilation
make[2]: *** [pnctestf] Error 1
make[2]: Leaving directory `/git/parallel-netcdf/test/fandc'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/git/parallel-netcdf/test'
make: *** [tests] Error 2
