pre-release: parallel-netcdf 1.0.2pre1 - configure on AIX
Christopher Subich csubich at math.uwaterloo.ca
Thu Feb 8 14:50:30 CST 2007
On 8-Feb-07, at 11:21 AM, Jim Edwards wrote:
> This is because I cannot run the mpi program which trys to
> determine MPI_Offset, setting MPI_Offset=8 in the environment
> before running configure solves the problem.   I suppose you could
> also configure with the cross compile mode as on bgl.
I submitted a correction to this a couple months back to this list;
there's a way to discover the size of MPI_Offset using only compile-
time checks, in the configure scripts.  I'm surprised that the change
didn't make it into the prerelease.
