pre-release: parallel-netcdf 1.0.2pre1 - configure on AIX
Rob Ross rross at mcs.anl.gov
Fri Feb 9 09:24:44 CST 2007
Hi Christopher,
We'll revisit it now.
Rob
Christopher Subich wrote:
> On 8-Feb-07, at 11:21 AM, Jim Edwards wrote:
>> This is because I cannot run the mpi program which trys to determine
>> MPI_Offset, setting MPI_Offset=8 in the environment before running
>> configure solves the problem.   I suppose you could also configure
>> with the cross compile mode as on bgl.
> I submitted a correction to this a couple months back to this list;
> there's a way to discover the size of MPI_Offset using only compile-time
> checks, in the configure scripts.  I'm surprised that the change didn't
> make it into the prerelease.
