pre-release: parallel-netcdf 1.0.2pre1 - configure on AIX
Jim Edwards edwards.jim at gmail.com
Thu Feb 8 10:21:44 CST 2007
This is because I cannot run the mpi program which trys to determine
MPI_Offset, setting MPI_Offset=8 in the environment before running configure
solves the problem.   I suppose you could also configure with the cross
compile mode as on bgl.
On 2/8/07, Jim Edwards <edwards.jim at gmail.com> wrote:
> I run into a configure problem on AIX 5.3 :
> checking for Fortran "integer*"... no
> configure: error: F77 does not support "integer*"
> On 2/7/07, Robert Latham <robl at mcs.anl.gov> wrote:
> > It has been quite some time (over a year!) since we sent out version
> > 1.0.1.  Mostly, things have "just worked", but lately we've gotten a
> > lot of great testing from several groups, and we've accumulated a
> > non-trivial set of patches.   1.0.1 was a good release, and I'd like
> > to repeat that for 1.0.2.  To that end, I'd like to see the recent
> > changes get some good testing before we make 1.0.2 "official".
> > Some of the changes in this pre-release:
> > - improved build process on IBM BGL systems
> > - improved build process when cross-compiling
> > - no more "return without calling MPI_Finalize" conditions
> > - improvements to our CDF-2 support
> > - build fixes for Darwin (Apple OS X)
> > - disable nonblocking API when built against MPI-1 implementations
> > http://www.mcs.anl.gov/parallel-netcdf has links to the download, in the
> > 'test releases' section.
> > Have fun!
> > ==rob
> > Rob Latham
> > Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
> > Argonne National Lab, IL USA                 B29D F333 664A 4280 315B
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20070208/de4e4b88/attachment.htm>
