Inconsistent results on bluegene
Yu-Heng Tseng YHTseng at lbl.gov
Thu Apr 13 01:27:43 CDT 2006
Here is the description of the problem.
In the test directory under test/fandc/
there is a Fortran test file called "pnf_test.F"
This file generates an array has size 256x256x256 and output it to a
pnf_test.nc file and read it back.
In other machines or using gcc to compile the library, it compares the
original array with the readin new array. The output have
diff, delmax, delmin
They should be all zero which represents the difference between the
new array and old array. Unfortunitely, I got some non-zero values
when I use 2, 8, 16 processors which means the new readin array and
original array are not identical.
The only correct result is using 1 processor. The new readin array is
identical to the old array.
I am not sure if there is anything wrong on the compiler or any
problem. It looks fine when I use gcc to compile. Thank you so much
for your help!
Yu-heng
Yu-Heng Tseng
Computational Research Division
Lawrence Berkeley National Laboratory
One Cyclotron Rd, MS: 50F-1650
Berkeley, CA94720
YHTseng at lbl.gov
510.495.2904
----- Original Message -----
Date: Wednesday, April 12, 2006 7:28 pm
Subject: Re: Inconsistent results on bluegene
> Hi,
> Can you describe how the results are inconsistent?
> Thanks,
> Rob
> Yu-Heng Tseng wrote:
> > Hi,
> > I am doing a testing on bluegene using. Surprisely, the results
> are not
> > consistent when I use
> > multiple processors. There is no error when I compile and
> install the
> > library  I believe.
> > I use the test case from /fandc/pnf_test.F
> > The compiler I am using is "blrts_xlc" I am not sure what cause
> the
> > problem.
> > But when I use gcc to compile it. The results are consistent for
> > Please give me some advices! Thanks!
> > Yu-heng
