Inconsistent results on bluegene
Rob Ross rross at mcs.anl.gov
Thu Apr 13 08:23:31 CDT 2006
I see. Can you tell us what BG/L you are running on, what file system it
has, and how it is mounted to the I/O nodes?
If not, can you CC someone that would know?
This could be an NFS thing.
Rob
Yu-Heng Tseng wrote:
> Hi,
> Here is the description of the problem.
> In the test directory under test/fandc/
> there is a Fortran test file called "pnf_test.F"
> This file generates an array has size 256x256x256 and output it to a
> pnf_test.nc file and read it back.
> In other machines or using gcc to compile the library, it compares the
> original array with the readin new array. The output have
> diff, delmax, delmin
> They should be all zero which represents the difference between the
> new array and old array. Unfortunitely, I got some non-zero values
> when I use 2, 8, 16 processors which means the new readin array and
> original array are not identical.
> The only correct result is using 1 processor. The new readin array is
> identical to the old array.
> I am not sure if there is anything wrong on the compiler or any
> problem. It looks fine when I use gcc to compile. Thank you so much
> for your help!
> Yu-heng
> Yu-Heng Tseng
> Computational Research Division
> Lawrence Berkeley National Laboratory
> One Cyclotron Rd, MS: 50F-1650
> Berkeley, CA94720
> YHTseng at lbl.gov
> 510.495.2904
> From: Rob Ross <rross at mcs.anl.gov>
> Date: Wednesday, April 12, 2006 7:28 pm
> Subject: Re: Inconsistent results on bluegene
>> Hi,
>> Can you describe how the results are inconsistent?
>> Thanks,
>> Rob
>>> Hi,
>>> I am doing a testing on bluegene using. Surprisely, the results
>> are not
>>> consistent when I use
>>> multiple processors. There is no error when I compile and
>> install the
>>> library  I believe.
>>> I use the test case from /fandc/pnf_test.F
>>> The compiler I am using is "blrts_xlc" I am not sure what cause
>> the
>>> problem.
>>> But when I use gcc to compile it. The results are consistent for
>>> Please give me some advices! Thanks!
>>> Yu-heng
