Inconsistent results on bluegene
Rob Ross rross at mcs.anl.gov
Wed Apr 12 21:28:05 CDT 2006
Can you describe how the results are inconsistent?
Rob
Yu-Heng Tseng wrote:
> Hi,
> I am doing a testing on bluegene using. Surprisely, the results are not
> consistent when I use
> multiple processors. There is no error when I compile and install the
> library  I believe.
> I use the test case from /fandc/pnf_test.F
> The compiler I am using is "blrts_xlc" I am not sure what cause the
> problem.
> But when I use gcc to compile it. The results are consistent for
> Please give me some advices! Thanks!
> Yu-heng
