Inconsistent results on bluegene
Yu-Heng Tseng yhtseng at lbl.gov
Wed Apr 12 18:54:22 CDT 2006
I am doing a testing on bluegene using. Surprisely, the results are not
consistent when I use
multiple processors. There is no error when I compile and install the
library  I believe.
I use the test case from /fandc/pnf_test.F
The compiler I am using is "blrts_xlc" I am not sure what cause the problem.
But when I use gcc to compile it. The results are consistent for
Please give me some advices! Thanks!
Yu-heng
