parallel-netcdf-0.9.0, NEC SX
rene.redler redler at ccrl-nece.de
Wed Sep 17 07:35:18 CDT 2003
Hello,
based on the parallel-netcdf-0.9.0 I downloaded on Monday this week
I did some first tests on the SX using the SX make (obviously close to
the UNIX make)
When trying to process the files in src/libf in order to add them to the
already existing libpnetcdf.a (from src/lib) the dependencies cannot be
resolved properly. The make builds the .o file in src/libf but does not
update the already existing libpnetcdf.a, perhaps because it does not
consider the date of the .o files but takes the date of the .f files
instead (which are of course older then the libpnetcdf.a). The simple
workaround was to invoke the make for src/libf twice. I am not sure
whether I should provide another portable solution to you for the
Makefile.in in src/lib and /src/libf or whether you already have some
ideas how to eliminate this particular problem.
When trying to create the Fortran tests nf_test and fandc the loader
terminated with an error because of undefined symbols. Reason is that
already all routines are defined in pnetcdf.inc, while not all are
implemented; and although declared as external the loader is expecting
them by default. To overcome this I had to specify a flag for the
compiler: -Wl"-h nodefs". I thought that this could be done by setting the
environment variable FFLAGS, but the Makefile in test/fandc does not use
FFLAGS at all and test/nf_test overwrites FFLAGS with something defined
elsewhere.
Taking this into account the Fortran tests fandc and nf_test succeeded.
Furthermore I noticed that pnetcdf.inc defines several routines nfmpi__*
which are probably not needed anymore and can perhaps be eliminated from
the pnetcdf.inc.
On the SX integer*1 does not exist which is correctly detected during
the configure step, and therefore no int1 interfaces are built.
Nevertheless they are defined in the pnetcdf.inc . Without the additional
flag (see above) this will remain a problem and requires the additional
flag when linking any application with the pnetcdf library. Such is not
required with the serial PnetCDF but unfortunately I don't know why. Any
ideas from your side?
Nevertheless it is tempting now to use your library for a parallel
application in the field of ocean modeling.
I am sorry for this long note.
Rene
   _______________________________________________________________
      René Redler
      C&C Research Laboratories
      NEC Europe Ltd.                   Tel: +49 (0)2241 925240
      Rathausallee 10                   Fax: +49 (0)2241 925299
      53757 Sankt Augustin              URL: www.ccrl-nece.de/~redler
