parallel-netcdf on a linux cluster
William Gropp gropp at mcs.anl.gov
Thu Sep 11 13:48:03 CDT 2003
At 11:53 AM 9/11/2003 -0700, John Tannahill wrote:
>Tried the suggestion below; still have the same problem.
Hmm.  Please send the output of the configure step.  Thanks!
Bill
>William Gropp wrote:
>>At 11:25 AM 9/11/2003 -0700, John Tannahill wrote:
>>>I believe that is the case:
>>>To install pnetcdf, I did:
>>>   setenv MPICC mpiicc
>>>   setenv MPIF77 mpiifc
>>Ah.  This explains the problem.  The GNU autoconf code is using the value
>>of F77.  Try doing
>>setenv F77 ifc
>>setenv CC icc
>>in addition and rebuilding.
>>Bill
>John R. Tannahill
>Lawrence Livermore Nat. Lab.
>P.O. Box 808, M/S L-103
>Livermore, CA  94551
>925-423-3514
>Fax:  925-423-4908
