parallel-netcdf on a linux cluster
John Tannahill tannahill1 at llnl.gov
Thu Sep 11 15:04:34 CDT 2003
/g/g17/jrt/pnetcdf_mcr/parallel-netcdf-0.9.0[136]: ./configure --prefix=/g/g17/j
creating cache ./config.cache
checking for top-level source-directory
checking for a BSD compatible install... /usr/bin/install -c
checking for m4 preprocessor
checking for m4... m4
checking m4 flags... -B10000
checking for gcc... icc
checking whether the C compiler (icc -O ) works... yes
checking whether the C compiler (icc -O ) is a cross-compiler... no
checking whether we are using GNU C... no
checking whether icc accepts -g... yes
checking for c++... c++
checking whether the C++ compiler (c++  ) works... yes
checking whether the C++ compiler (c++  ) is a cross-compiler... no
checking whether we are using GNU C++... yes
checking whether c++ accepts -g... yes
checking how to run the C preprocessor... icc -E
checking for f77... f77
checking for Fortran .F compiler...
checking if Fortran-77 compiler handles *.F files... yes
checking how to make dependencies... false
checking for nm utility
checking for nm... nm
checking nm flags...
checking for C-equivalent to Fortran routine "SUB"... sub_
checking for math library
checking for tanh in -lc... yes
checking for ar utility
checking for ar... ar
checking ar flags... cru
checking for nm... (cached) nm
checking for ranlib... ranlib
checking for C-equivalent to Fortran routine "SUB_A"... sub_a__
checking MPI-IO support in MPI implementation... yes
checking for stdlib.h... yes
checking for sys/types.h... yes
checking for strerror... yes
checking for working ftruncate()... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for st_blksize in struct stat... yes
checking for IEEE floating point format... yes
checking for ANSI C header files... yes
checking for size_t... yes
checking whether size_t and int size match... yes
checking for off_t... yes
checking for ssize_t... yes
checking for ptrdiff_t... yes
checking for uchar... no
checking whether char is unsigned... no
checking whether byte ordering is bigendian... no
checking size of short... 2
checking size of int... 4
checking size of long... 4
checking size of float... 4
checking size of double... 8
checking size of off_t... 4
checking size of size_t... 4
checking for Fortran "byte"... yes
checking for Fortran "integer*2"... yes
checking if Fortran "byte" is C "signed char"... yes
checking if Fortran "byte" is C "short"... no
checking if Fortran "byte" is C "int"... no
checking if Fortran "byte" is C "long"... no
checking if Fortran "integer*2" is C "short"... yes
checking if Fortran "integer*2" is C "int"... no
checking if Fortran "integer*2" is C "long"... no
checking if Fortran "integer" is C "int"... yes
checking if Fortran "real" is C "float"... yes
checking if Fortran "doubleprecision" is C "double"... yes
checking for Fortran-equivalent to netCDF "byte"... byte
checking for Fortran-equivalent to netCDF "short"... integer*2
checking for manual-page index command...
checking binary distribution directory... /home/ftp/pub/binary/dummy_system
updating cache ./config.cache
creating ./config.status
creating macros.make
creating Makefile
creating src/Makefile
creating test/Makefile
creating src/lib/Makefile
creating src/libf/Makefile
creating test/common/Makefile
creating test/test_double/Makefile
creating test/test_double_int/Makefile
creating test/test_float/Makefile
creating test/test_int/Makefile
creating test/nc_test/Makefile
creating test/nf_test/Makefile
creating test/fandc/Makefile
creating src/lib/ncconfig.h
William Gropp wrote:
> At 11:53 AM 9/11/2003 -0700, John Tannahill wrote:
>> Tried the suggestion below; still have the same problem.
> Hmm.  Please send the output of the configure step.  Thanks!
> Bill
>>> At 11:25 AM 9/11/2003 -0700, John Tannahill wrote:
>>>> I believe that is the case:
>>>> To install pnetcdf, I did:
>>>>   setenv MPICC mpiicc
>>>>   setenv MPIF77 mpiifc
>>> Ah.  This explains the problem.  The GNU autoconf code is using the
>>> value of F77.  Try doing
>>> setenv F77 ifc
>>> setenv CC icc
>>> in addition and rebuilding.
>>> Bill
>> John R. Tannahill
>> Lawrence Livermore Nat. Lab.
>> P.O. Box 808, M/S L-103
>> Livermore, CA  94551
>> 925-423-3514
>> Fax:  925-423-4908
       |                                          John R. Tannahill           |
       |    _/      _/      _/    _/  _/          Lawrence Livermore Nat. Lab |
       |   _/      _/      _/_/  _/  _/           P.O. Box 808, M/S L-103     |
       |  _/      _/      _/  _/_/  _/            Livermore, CA  94551        |
       | _/_/_/  _/_/_/  _/    _/  _/_/_/         Phone:  925-423-3514        |
       |                                          Fax:    925-423-4908        |
       | Lawrence Livermore National Laboratory   Email:  jrt at llnl.gov        |
