parallel-netcdf on a linux cluster
John Tannahill tannahill1 at llnl.gov
Thu Sep 11 13:53:51 CDT 2003
Tried the suggestion below; still have the same problem.
William Gropp wrote:
> At 11:25 AM 9/11/2003 -0700, John Tannahill wrote:
>> I believe that is the case:
>> To install pnetcdf, I did:
>>   setenv MPICC mpiicc
>>   setenv MPIF77 mpiifc
> Ah.  This explains the problem.  The GNU autoconf code is using the
> value of F77.  Try doing
> setenv F77 ifc
> setenv CC icc
> in addition and rebuilding.
> Bill
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA  94551
925-423-3514
Fax:  925-423-4908
