version 0.9.1 is released
Tyce Mclarty mclarty3 at llnl.gov
Wed Oct 8 15:48:38 CDT 2003
I tried 0.9.1 here at LLNL with good results.
I just used the info in README.SP to build and it works fine, so you no
longer need to carry special README's for LLNL's frost machine.
I did not see anything about changes in API or functionality so I assume
those are unchanged, and this release has no impact at the application level?
I intend to try Rene's Makefile mods in the next couple of days to verify
it on SP machines. Will let you know.
Nice work,
Tyce
At 03:09 PM 10/7/2003 -0500, Robert Latham wrote:
>Hello
>Short summary: parallel-netcdf-0.9.1 is available.
>http://www.mcs.anl.gov/parallel-netcdf/
>Thanks to everyone who tried out version 0.9.0.  After some
>initial build issues, we haven't had many complaints this month, which
>is fine by me.
>We've made a pass through the build issues and have addressed most if
>not all of the problems people encountered when installing 0.9.0.
>Rene, one issue we did not fix yet was the problem you encountered
>where the Fortran objects were not added to libpnetcdf.a.  I've
>documented your workaround in README.SX
>Changes in 0.9.1:
>. removed the unused nctest test
>. fix some build issues with the test programs on different platforms
>. no longer checks for a C++ compiler
>. --disable-fortran *really* disables building the Fortran interface
>. FC and F77 are equivalent ways to specify the Fortran compiler
>Have fun!
>==rob
>Rob Latham
>Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
>Argonne National Labs, IL USA                B29D F333 664A 4280 315B
