version 0.9.1 is released
Rob Ross rross at mcs.anl.gov
Wed Oct 8 16:02:26 CDT 2003
On Wed, 8 Oct 2003, Tyce Mclarty wrote:
> I tried 0.9.1 here at LLNL with good results.
> I just used the info in README.SP to build and it works fine, so you no
> longer need to carry special README's for LLNL's frost machine.
Excellent.
> I did not see anything about changes in API or functionality so I assume
> those are unchanged, and this release has no impact at the application level?
Correct.  Just minor stuff to make builds go as cleanly as possible.
> I intend to try Rene's Makefile mods in the next couple of days to verify
> it on SP machines. Will let you know.
> Nice work,
> Tyce
Thanks!  And thanks for reporting back results of trying it.
Rob
